Compression test - Kawasaki ZX-10R.net
post #1 of 9 Old 05-19-2007, 08:26 PM Thread Starter
Compression test
When we do a compression test on a zx-10r, did the motor as to be cold, or hot ????
Valve clearance checking ???? Motor hot or cold ????
Thanks.
I still wait for my shop manual but in cas somebody know.
ninja_12r2000 is offline
post #2 of 9 Old 05-19-2007, 08:40 PM
Dragone's Avatar
Images: 11
compression and leak down tests are only to see what the base line is and to see which is the weak area.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #3 of 9 Old 05-19-2007, 08:44 PM Thread Starter
Compression
I know.
So in my old time the compression test where taken motor hot, 10 cranks, and the difference between the cylinder was check that way. But the thing are the moment you get to the spark plugs on zx-10r the motor is not exactly what we call hot, that's the purpose of my question.
post #4 of 9 Old 05-19-2007, 08:56 PM
engine cold or hot does not matter as long as you are just trying to find a leaky cylinder.....
A proper compression test requires that you put a few squirts of engine oil into the cylinder to seal the piston rings - that means that it won't really make (MUCH) difference if the engine is cold because the oil will help to seal the rings to the cyl-walls to create compression.....
Also, you will suffer great pains trying to pull plugs out of a HOT engine. !!!!!!!!!!!!!
fordfasterr is offline
post #5 of 9 Old 05-19-2007, 10:02 PM
Dragone's Avatar
Images: 11
yeah, pretty much. If 3 cylinders are at lets say 110psi and one cylinder is 60psig, then something is amiss. I never did the oil thing though.
Dragone is offline
post #6 of 9 Old 05-19-2007, 10:08 PM
Daves Cycles's Avatar
compression test
Well the correct way is with the engine cold,full throttle, crank till you get max reading.Don't use oil.Only use oil if you get a cylinder that reads low, give it a couple of shots of oil .If the pressure comes up your getting ring blow by,if it doesn't you have a valve not sealing
05 green ZX10R,Akrappovic Evo 2 Carbon w/ hex shorty can full exhaust system,Power Commander USB,Radial front master cylinder(636),Goodridge front and rear carboline brake lines,07 CBR1000RR front brake calipers,Vesrah race front brake pads,Targa tail kit,flush mount front signals,Cabon fiber led rear signals,Ohlins steering dampers,-1 front,Speedo Healer, Pilot Power tires,Gipro Tre and gold Sato's rearsets.
Daves Cycles is offline
post #7 of 9 Old 05-19-2007, 10:14 PM
Dragone's Avatar
Images: 11
Dang, hate forgetting. Thanks for the reminder.
Dragone is offline
post #8 of 9 Old 05-20-2007, 01:48 PM
10rmotor's Avatar
Valve clearance checking I've always done cold. Not a couple hours since last ridden. COLD.
10rmotor is offline
post #9 of 9 Old 05-21-2007, 07:12 AM Thread Starter
Found the problem
Well compression test tell me that was something wrong.
Found it a bent valve. So know I got to replace it.
Somebody got the experience of pulling out the head of this zx-10r 2004-05 ???
Good place to buy valves and probably seat and seal, and head gasket ?????
What was the hing with the thin head gasket ?????
Did the bike could work with pumping gas after that ???
Any advice welcome, maybe on the tech section.
Stock Low Compression Piston Modifacation Suzuk1ki11a Performance and Tech 10 01-07-2007 10:36 AM
2mm bore and 2mm stroke compression anyone? garth285 Performance and Tech 13 07-02-2006 12:43 AM
MotoGP compression suit projekZERO Vendors deals 28 05-05-2006 05:23 PM
? backing out compression on rear shock speedkelly The ZX-10R 45 11-23-2005 09:29 AM
Raising The Compression Ratio????? SP8 Performance and Tech 12 11-24-2004 09:30 AM
