Gen 1: 2004-2005 Compression Check done today - Kawasaki ZX-10R.net
post #1 of 6 Old 04-02-2011, 10:11 PM Thread Starter
bluedevil's Avatar
Ok....your suppose to do it after getting the engine warm then take everything apart and measure......well I didn't go that fast and the bike was kind of cold.. but was more concerned about 1 cylinder after doing the Valve adjustment.....wanted to see if there was something different there but so far the answer is no.
After about 5 cranks or a little more on EACH measurement each Cylinder was getting the exact same measurement even though it was somewhat cold.
1-4 180PSI all THE SAME.....book says hot 159-242PSI(20R/Min) but happy they are ALL the same and still in spec this bike must have over 30k miles and still runs very strong.
bluedevil is offline
post #2 of 6 Old 04-02-2011, 10:14 PM
dirt ninja's Avatar
Images: 9
Good deal blue.
dirt ninja is offline
post #3 of 6 Old 04-02-2011, 10:14 PM
09zx10miami's Avatar
Good stuff.....Kawi's can go the distance...
09zx10miami is offline
post #4 of 6 Old 04-02-2011, 10:23 PM
codyc_13's Avatar
Awesome news, have you been able to ride her since the valve adjustment? Also on an unrelated note I remember awhile back you said that you were having clutch issues, and in another thread I mentioned my bike was very difficult to slide the clutch and you mentioned yours did the same thing.
My ? Is have you inspected the actual clutch basket, that ended up being my problem, my steels actually dug groves into my basket.
codyc_13 is offline
post #5 of 6 Old 04-02-2011, 10:25 PM Thread Starter
bluedevil's Avatar
that's what I have been thinking and why I bought a Kawi in the first place....ok again.
My old late 80s honda was good too for awhile but my ZX9R ninja stood strong for 20k before I sold it not even a valve adjustment......this old 1st Gen though has been the best though so far when you count the performance you get and fun factor for little money.
bloo
post #6 of 6 Old 04-02-2011, 10:27 PM Thread Starter
bluedevil's Avatar
yes bud I seen your thread I will check it out and thanks for that info....might try to hit the strip next Wed. to see how my clutch is working ....but will definitely look closer if need be for things like you stated...thanks
how much compression???? inginekilla Performance and Tech 7 11-12-2010 01:40 PM
spring compression RDLYN13000 Performance and Tech 2 09-19-2009 07:42 PM
compression ??? supperdaddy Performance and Tech 17 12-25-2007 01:13 PM
Compression test ninja_12r2000 Performance and Tech 8 05-21-2007 08:12 AM
check out what came in today! CroatianSensation Pictures and Videos 30 03-03-2007 11:42 PM
