Gen 1: 2004-2005 Clutch Spring Pressure - Kawasaki ZX-10R.net
post #1 of 16 Old 05-04-2011, 10:12 AM Thread Starter
10R_Havens's Avatar
Need to know the spring pressure of each spring in the clutch. I searched and saw somewhere that the '06 is right around 62 lbs. per spring, but this is for a '04 model.
10R_Havens is offline
post #2 of 16 Old 05-05-2011, 11:23 AM Thread Starter
10R_Havens's Avatar
Nobody eh?
post #3 of 16 Old 05-05-2011, 11:31 AM
Speed Freak
garth285's Avatar
they are the same 60-65lbs, barnett has stiffer springs all the way up to 100's if you need them.
I am running 3 stock springs and 3 100's in my 2011 right now
MT-91-6 were the 100's I believe
garth285 is offline
post #4 of 16 Old 05-05-2011, 11:45 AM Thread Starter
10R_Havens's Avatar
At 60-65 lbs, that's between 360-390 lbs of static spring pressure!
post #5 of 16 Old 05-05-2011, 11:46 AM
Speed Freak
garth285's Avatar
is that not good?
garth285 is offline
post #6 of 16 Old 05-05-2011, 11:51 AM Thread Starter
10R_Havens's Avatar
is that not good?
Seems high to me. Thanks for the confirming the spring pressure for me.
post #7 of 16 Old 05-05-2011, 11:54 AM
Speed Freak
garth285's Avatar
No Prob, yeah I believe they are 62's stock then barnett sells I think 75, 85s and 100's
I am running 3 100's and 3 stockers so stock pack would be 372lbs I would be at 486lbs but I do a lot of top end stuff so I want my pack tight
garth285 is offline
post #8 of 16 Old 05-05-2011, 12:29 PM
Squid wannabe
rafa's Avatar
Dont mean to thread jack.... but what do you guys run for plates on your 1st gens?
I heard that in between the 1st 2nd and 3rd gen, the 1st had the best plates, is there any aftermarket ones that would be better or just oem is fine?
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #9 of 16 Old 05-05-2011, 01:43 PM
Speed Freak
garth285's Avatar
Call up Dwaye at Cycle Concepts he has a "Drag Pack" for the zx10r's that holds up very well. I'll probably change mine over after a few more top end runs soon.
garth285 is offline
post #10 of 16 Old 05-05-2011, 01:48 PM
codyc_13's Avatar
Garth do you want to get rid of your other 3barnett springs? I'm in need of some heavy springs BAD.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
Clutch pressure rod problem, How frequent? STEPH93LX Performance and Tech 22 05-07-2017 03:28 AM
04 clutch spring shims? gazx10 Performance and Tech 2 05-05-2010 11:32 AM
08 Clutch spring upgrade? strkd50 Performance and Tech 8 11-27-2009 09:56 AM
how to change clutch pressure rod fordfasterr Performance and Tech 20 06-28-2009 08:33 AM
Clutch Pressure Der Yeager The ZX-10R 23 11-08-2005 07:18 PM
