Clutch question - Kawasaki ZX-10R.net
post #1 of 4 Old 11-28-2008, 10:35 AM Thread Starter
Clutch question
Ok guys here is the deal, I have an 07 ZX10r and what seems to be the problem that feels like maybe my clutch is not disengaging all the way... In the morning when i try to move my bike while in the off position and into 1st gear if i press the clutch all the way in it should roll freely or should it have some clutch drag? It only does it when the clutch is cool off cause Once i get going and stop with the bike warmed I dont experience the drag anymore if in gear and holding the cluch in it will now roll freely .. What could be the problem? Is it normal? Also the gears are hard to get in sometime ... Help!
The Hulk is offline
post #2 of 4 Old 11-28-2008, 11:10 AM
bluedevil's Avatar
Sounds like it's not adjusted right and you also you need to Soak the clutch plates.
https://www.zx-10r.net/forum/showthread.php?t=6525
bloo
bluedevil is offline
post #3 of 4 Old 11-28-2008, 12:00 PM Thread Starter
Interesting...thanks
The Hulk is offline
post #4 of 4 Old 11-28-2008, 12:30 PM
TMAC's Avatar
Images: 86
Is this only an issue when you are in gear? It's normal for there to be a little drag even with the clutch in while you are in gear with the bike off, but you should still be able to push the bike around.
2007 ZX-10R - 156 RWHP/182 MPH
2009 KX450F
2006 636 (Sold)
99 ZX-6R (Sold)
94 Ninja 250 (Sold)
99 YZ-250 (Sold)
73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htm
TMAC is offline
08 Clutch Question? 347 tony Performance and Tech 5 10-28-2008 04:31 AM
Clutch question 04 zx-10 Gutz The ZX-10R 4 07-18-2008 12:40 AM
04 Clutch question Riddick Performance and Tech 8 10-03-2006 02:30 PM
clutch hub nut question Vince10R Performance and Tech 9 08-25-2006 01:09 PM
Clutch Question SiP Racing09 ZX-7, ZX-7R & ZX-7RR Discussion 1 04-10-2006 12:13 AM
