Clutch noise - Kawasaki ZX-10R.net
post #1 of 3 Old 04-23-2008, 10:25 PM Thread Starter
afskypilot's Avatar
Clutch noise
I was parked today waiting for a friend to join me for a ride when I shifted into neutral and when I let out the clutch I noticed a slight vibration and a soft growling sound. I pulled in the clutch and it disappeared. The only thing I have done clutch wise is switch to synthetic oil. Is this something I should worry about? Problem is, I have only had the bike out on the road twice after almost 7 months in the garage (long winters in AK). What do I need to check, if anything? I look forward to your wisdom.
afskypilot is offline
post #2 of 3 Old 08-28-2008, 02:40 PM
zed-x user's Avatar
Ok I have a slight noise with the clutch out and when I pull it in the noise gets worse, kinda sounds like a Ducati clutch. any wisdom for me?
zed-x user is offline
post #3 of 3 Old 08-28-2008, 09:18 PM
bugman53's Avatar
It is just the transmittion bearings no big deal there a little noisy. It could be the bearing in the pressure plate, but you would hear that with the clutch in not out.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
Noise after I install clutch basket!!! quikgix Performance and Tech 5 10-15-2010 09:38 AM
06 Zx10r Clutch/gearbox Noise (need Help) 06ZX10R-TRINI Performance and Tech 1 10-12-2007 05:52 PM
06 Zx10r Clutch/gearbox Noise (need Help) 06ZX10R-TRINI Welcome Newbies! 10 10-11-2007 09:52 PM
Clutch noise? Help! lunitk Performance and Tech 18 11-23-2006 03:32 AM
Clutch making noise when engaged. JIKSER Performance and Tech 1 10-14-2005 10:07 AM
