Clutch issues - Kawasaki ZX-10R.net
post #1 of 5 Old 12-08-2010, 08:07 PM Thread Starter
sullysZX10r's Avatar
Clutch issues
I sadly went down for the first time at the track a few weeks back. After patching up my radiator and replacing my generator cover, I now find that I can not shift into second gear at all. Before all of this I could shift up to 6th with the bike at idle. I switched over to moto GP style and I could shift into 2nd by pushing down, but could not go into first (up).
Any suggestions?
Thanks in advance.
sullysZX10r is offline
post #2 of 5 Old 12-09-2010, 04:06 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Bent shift rod/arm? have you tried switching it back to the stock shift setup?
TMY10ER is offline
post #3 of 5 Old 12-09-2010, 04:11 PM Thread Starter
Yeah, and its the same thing. I found a thread on here that explains that. It seems minor, so I will inspect
post #4 of 5 Old 12-09-2010, 07:02 PM
Kawawog's Avatar
Send a message via MSN to Kawawog
The lever attached to the shift rod that is on the clutch side will most definately have a crack or 2 in it.. Same happened to my 09 when i lowsided..
I ended up finding 2 hairline cracks in it(only just) which was enough to affect shifting when the engine warmed up..
The shift rod asessembly has now been upgraded to a better one for the 08-10 models as the original was rubbish
Id start there dude, all the best
Kawawog is offline
post #5 of 5 Old 12-09-2010, 08:17 PM Thread Starter
Thanks guys. After I switched from gp, I took it for a spin and it is engaging all gears. Thanks for the tips. I was worried. I am dying to ride, but its in the damn 20s-30s here.
Thanks again guys!
Clutch Issues Gr33nG0bl1n Performance and Tech 11 04-22-2010 07:15 PM
'06 Clutch issues Gang Green Performance and Tech 1 08-17-2008 11:05 PM
Clutch issues Killentime Performance and Tech 5 05-19-2007 03:20 PM
Clutch issues GARSZX10R Performance and Tech 55 09-14-2006 12:56 AM
Clutch issues dr_wookiee Performance and Tech 5 06-29-2005 11:18 PM
