Clutch install and adjustment>?? - Kawasaki ZX-10R.net
post #1 of 1 Old 08-10-2007, 12:23 PM Thread Starter
zx10BLADE's Avatar
OK, so i am finally replacing my clutch after 19,000 miles. I am going with the Barnett Clutch Pak w/ springs, 10 friction plates, 10 steel plates+new gasket. Th Barnett steel plates have 8 plates the same thickness and theres 2 that are slightly thinner. The OEM has 10 friction and 8 steel plates and 1 double steel plate. My question is do i reuse the factory double steel plate and use the regular 8 steel Barnette Plates, or do i not use the double steel plate and use the two thinner plates i recieved with my kit. My 2nd question is.....Is the double steel plate the slipper ???? I have never isntalled a Slipper before so i need some of your guys wisdom on this matter
BLADE
https://zx-10r.net/forum/image.php?type=sigpic&userid=4109&dateline=1184855  127
Your Current Signature Picture
zx10BLADE is offline
04 636 clutch adjustment how to reckless1 ZX-6R & ZX-6RR Archives 3 03-05-2007 04:35 PM
clutch adjustment**UPDATE** norcal10 Performance and Tech 8 08-27-2006 09:33 AM
clutch adjustment bigsill Performance and Tech 14 07-14-2006 08:53 AM
Clutch cable adjustment BlackNinja The ZX-10R 1 05-18-2004 09:10 PM
Slipper clutch adjustment? Floyd The ZX-10R 0 05-02-2004 12:48 PM
