Clutch Inner Scraps/Marks - Kawasaki ZX-10R.net
post #1 of 13 Old 10-16-2010, 09:09 PM Thread Starter
bluedevil's Avatar
Anyone ever had this....just pulled my cover replacing clutch fibers and steels but never noticed this and see no shavings....but at the same time I don't see how this could happen.
ID:	137774   Click image for larger version
bluedevil is offline
post #2 of 13 Old 10-16-2010, 09:36 PM
gazx10's Avatar
grooves/marks
my 04 had same groove in cover, didnt appear to be from interference. a added safety margin when hub springs loosen and basket wobbles a little maybe? marks on outer hub appear to be clamp marks from holding fixture while machining blank hub. believe both are normal from the factory.
gazx10 is offline
post #3 of 13 Old 10-16-2010, 09:37 PM
RDLYN13000's Avatar
Images: 38
I know that groove on your cover is normal but im not sure about the scratches?
RDLYN13000 is offline
post #4 of 13 Old 10-17-2010, 01:57 PM
Send a message via AIM to Cycle Concepts
all is normal..
Cycle Concepts is offline
post #5 of 13 Old 10-17-2010, 03:13 PM
Lougots's Avatar
Originally Posted by cycle concepts View Post
all is normal..
Lougots is offline
post #6 of 13 Old 10-19-2010, 12:38 AM Thread Starter
bluedevil's Avatar
Originally Posted by Cycle Concepts View Post
all is normal..
Thanks bud......
post #7 of 13 Old 10-19-2010, 07:37 AM
mdzx10r's Avatar
looks like my 04 did.
mdzx10r is offline
post #8 of 13 Old 10-19-2010, 07:53 AM
KevinF's Avatar
Looks like mine as well. Glad this topic came up. That knotch in the cover had me a nervous.
KevinF is offline
post #9 of 13 Old 10-19-2010, 09:11 AM
Judge Dredd Mod
mr_honez's Avatar
all is normal..
:iamwithst
Looks just like mine did.
BURNOUT.....
mr_honez is offline
post #10 of 13 Old 10-20-2010, 12:39 AM
tasos's Avatar
I had this issue when i put my billet basket in. It was 05mm bigger than the original. I Put the stock back and it was ok. It also made a weird sound when not engaged. My groove was way bigger than this.
Just check if everything is ok. Gen1 clutches make weird noises when cold
Last edited by tasos; 10-20-2010 at 12:47 AM. Reason: Checked again, the groove is normal
tasos is offline
On your Marks, Get Set, Goooooooooo.............! horse Performance and Tech 10 01-27-2009 12:53 PM
swirl marks FastAsHellZX10 The ZX-10R 10 02-04-2008 09:12 PM
Cleaning water marks from TI can!?!? zx-10r203 The ZX-10R 9 07-21-2007 10:53 PM
anyone have rub marks on the frame protectors? busaforhire The ZX-10R 21 08-03-2005 12:04 PM
Check out these interesting marks on my tires. Captain Jack Pictures and Videos 43 07-01-2005 06:46 PM
