Clutch Hub Noise? - Kawasaki ZX-10R.net
post #1 of 6 Old 12-07-2008, 10:59 PM Thread Starter
Clutch Hub Noise?
OK, I don't know my head from my a** when it comes to mechanics, but I have an '04 and recently started hearing a grating/grinding noise coming from inside the clutch cover, but only when pulling the clutch in while rolling in gear. didn't make any sound with the clutch engaged, and sound disappeared if you threw it into neutral while coasting. I took it to a local dealer, the mechanic took it for a spin and diagnosed it as a possible broken clutch spring or something else inside the clutch. After I found Vonstallin's excellent post on how to change a clutch, I thought what the hey, and decided tear into it myself. After opening it up, no broken springs, just changed the friction plates as the were pretty worn (steel plates looked fine). Result: easier power wheelies, but sound still there when you disengage the clutch. Took the cover back off and removed the plates, noticed when you spin the inner hub by hand, feels and sounds like a bad bearing somewhere in there. It definitely makes a clunky noise if you alternate spinning it back and forth. Don't know where to go from here... anyone???
marktor is offline
post #2 of 6 Old 12-07-2008, 11:01 PM
Green Hippie
treyzx10r's Avatar
04 's have a bad rep for alternator failure that is really bad, might want to check into that before further operation
https://zx-10r.net/forum/showthread.p...ator+failur e
VAE VICTUS!
treyzx10r is offline
post #3 of 6 Old 12-07-2008, 11:04 PM
Green Hippie
treyzx10r's Avatar
oh and aboard
VAE VICTUS!
post #4 of 6 Old 12-07-2008, 11:46 PM Thread Starter
That alternator thing sounds pretty nasty. I read the part saying "if the assy isn't shimmed properly, the shaft can wobble too much and take out the center bearing in the housing." What bearings am I feeling when I spin the inner clutch hub by hand?
marktor is offline
post #5 of 6 Old 12-07-2008, 11:48 PM Thread Starter
oh and aboard
And thanks for the welcome!
marktor is offline
post #6 of 6 Old 02-19-2009, 03:49 PM
i have an 06 and recently had the same problem. pull all the clutch plates out and then pull the center hub nut off. the whole basket assembly will then slide out. the basket is riveted to the fly wheel by three rivets. i snapped off two of those rivets. check those out. i had the same noises you were talking about.
general8444 is offline
Noise after I install clutch basket!!! quikgix Performance and Tech 5 10-15-2010 09:38 AM
Clutch noise afskypilot Performance and Tech 2 08-28-2008 09:18 PM
06 Zx10r Clutch/gearbox Noise (need Help) 06ZX10R-TRINI Performance and Tech 1 10-12-2007 05:52 PM
06 Zx10r Clutch/gearbox Noise (need Help) 06ZX10R-TRINI Welcome Newbies! 10 10-11-2007 09:52 PM
Clutch noise? Help! lunitk Performance and Tech 18 11-23-2006 03:32 AM
