Gen 4: 2011-2015 Clutch holder absolutely necessary? - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By PatrickG
post #1 of 6 Old 08-24-2014, 11:01 AM Thread Starter
Mastermind's Avatar
My bike has just over 4,000 miles on it and the clutch is slipping to where its unsafe to ride. I've already tried adjusting the clutch cable and no luck. I downloaded the service manual for a 2011 in another thread and the manual states that I need a "clutch holder". Is this tool really necessary? Is there anyone here that has an extra one that I can buy if I need one? I'm having problems finding a clutch cover gasket online. Can I just use Grey RTV to install the clutch cover or do I need to find a gasket for the housing? The clutch repair kit I purchased was the EBC SRK complete clutch kit. My riding style consists of numerous highway pulls (rpm's up then dump the clutch), rolling burnouts and several 9 second passes in the quarter mile at the track.
Mastermind is offline
post #2 of 6 Old 08-24-2014, 11:16 AM
SkyDork's Avatar
It is if you plan to remove the inner basket. If you're just replacing the drive and friction plates, then no. But Motion Pro makes one for about $30.
Get a new gasket. Don't half ass it and try to use the silicone. If you're gonna do the job yourself, do it right.
#WordCrimes
SkyDork is offline
post #3 of 6 Old 08-24-2014, 11:16 AM
You only need a clutch holder if your removing the inner hub, and so no, not needed if just replacing the fibers and or steels.
You should be able to re-use the stock gasket.
Watch this Brocks video. It shows how to remove the inner hub without a clutch holder if you have an impact wrench, otherwise you need a clutch holder if removing inner hub with just a wrench. Good luck with that.
Sounds like you DONT NEED TO REMOVE the inner hub doing what your going to do, so no, you don't need the holder.
https://www.youtube.com/watch?v=eryt...PVGtst3PN_MXug
Boxtradamus is offline
post #4 of 6 Old 08-24-2014, 12:54 PM
PatrickG's Avatar
Images: 15
+2 on above.
The gen4 gasket can be reused with NO issues. The oil level is below the cover so it is only splashed again the cover. Unlike the previous Generations which sat in oil and may eventually leak if you reused the cover gasket.
Personally, I have reused my stock gen4 clutch cover gasket for 2 years of dragracing, this means taking the clutch apart every weekend from March til Oct. This is only my experience though.
dudewhrsmybike likes this.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #5 of 6 Old 08-24-2014, 02:44 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Originally Posted by PatrickG View Post
+2 on above.
I reused mine as well. Good point about the oil on the Gen4 and previous Gen's
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #6 of 6 Old 08-25-2014, 10:23 AM Thread Starter
Mastermind's Avatar
I appreciate all the input guys!
Tags
clutch tool gasket rtv
Gen 3: Absolutely BadAss ;D SmgZx10r The ZX-10R 40 09-01-2014 02:02 AM
Absolutely ridiculous Iridium The Out House 22 10-26-2006 03:14 PM
Absolutely disgusting! DethsZX10 The Out House 23 03-18-2006 05:30 PM
Absolutely Priceless mach_man_187 The Out House 3 08-30-2005 10:56 PM
