Gen 1: 2004-2005 clutch doesn't grab - Kawasaki ZX-10R.net
post #1 of 19 Old 10-05-2014, 06:45 PM Thread Starter
zx10rzerecta's Avatar
clutch doesn't grab
I have a 2005 zx10r at first my clutch was slipping at high rpm. I changed the clutch and cable and the problem has gotten worse. Now the clutch will not grab
zx10rzerecta is offline
post #2 of 19 Old 10-05-2014, 06:52 PM Thread Starter
In first gear it just revs. I put the plates in as followed fiber, anti-chatter, fiber, steel, fiber etc. Does anyone know the proper configuration if that is not correct?
post #3 of 19 Old 10-05-2014, 08:27 PM
zx racer's Avatar
Thats the correct way they go in. Go back over everything, check your stack height and clutch rod make sure its workin properly probly just something you missed.
05 ZX-10R SWB.
zx racer is offline
post #4 of 19 Old 10-06-2014, 01:20 AM Thread Starter
What is the correct stack height. Can the ebc clutch kit I used be the problem?
post #5 of 19 Old 10-06-2014, 01:44 AM
bluedevil's Avatar
YES....and also if the housing plate was not seated right I don't remember if that's still possible to check but like zxracer said re-check the install...go the the "how to" section on this forum there is a thread on this but if the pics are missing just do a search you should see how the stack should look before being button up.
Also search Garth on this site he hosts the manual as well.
Bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #6 of 19 Old 10-06-2014, 07:06 AM
keithk's Avatar
you also have to stagger the first plate. I am pretty sure it was the first plate or the last cant remember?
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #7 of 19 Old 10-06-2014, 07:49 AM
gazx10's Avatar
hate to ask, but had a customer buy a new clutch for his ten, drive 1 hr. here for install,cable was so tight on old clutch plates would not engage, adjusted cable, clutch strong. had a zx9 same way, brought for clutch, just needed adjustment. got freeplay in clutch lever?
gazx10 is offline
post #8 of 19 Old 10-06-2014, 09:27 AM Thread Starter
Yes I staggered the last plate one notch over still no clutch response
post #9 of 19 Old 10-06-2014, 09:31 AM Thread Starter
And also adjusted cable at the lever and the one next to the engine no response
post #10 of 19 Old 10-06-2014, 10:20 AM Thread Starter
clutch doesn't grab
I'm having serious problems with my gen 1. I replaced the clutch and cable and assembled as followed fiber, anti-chatter, fiber, steel, fiber, steel, fiber, steel, fiber etc but clutch slips bad. First gear just revs and doesn't catch at all. I'm used new ebc kit. I have adjusted the cable at the lever and engine with no response. And last fiber is one notch over. Please help.
Can you grab my camera? or10r Pictures and Videos 9 09-19-2014 08:07 AM
Gen 4: Clutch doesn't seem to release right away? teedub21 The ZX-10R 23 05-22-2012 09:35 PM
Grab one now at $149.99 zx10rich eBay & Auction Links 10 05-28-2011 02:15 PM
Grab Bars Bond The ZX-10R 6 06-29-2010 06:42 AM
Passenger Grab Handles? Russell2566 The ZX-10R 3 03-25-2008 06:04 PM
