>> Clutch Break-in & Oil Change << - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SkyDork
post #1 of 6 Old 09-20-2018, 02:41 PM Thread Starter
Melampus's Avatar
Question >> Clutch Break-in & Oil Change <<
So I've got just over 500 miles on all new friction & drive plates that I recently installed along with full synthetic oil & new oil filter. Does current consensus dictate I should change out all this new oil? If so, you think I should change the filter, too? Can I just change the filter, and retain this brand new oil?
Thanks a lot for any opinions. I've been out of the loop for a decade now, and I'm curious as to if my dated knowledge still applies.
Melampus is offline
post #2 of 6 Old 09-21-2018, 05:02 AM
97grnrs's Avatar
I always do just to get rid of break in fibers, probably don't have to but I do
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #3 of 6 Old 09-21-2018, 08:44 AM
SkyDork's Avatar
That's a new one for me. It's a wet clutch. There's no break-in for it. The fiber plates will always wear down from use, but there's no magic break-in period for them like engines have. That is related to the assembly lube and the piston ring mating. No break-in or oil change is needed for clutch changes.
GreenWeenie likes this.
#WordCrimes
SkyDork is offline
post #4 of 6 Old 09-21-2018, 08:01 PM
97grnrs's Avatar
Actually you will get more clutch fibers during break in just from excess material on plates from manufacturing etc. I've seen it more than once in freshly drained oil. But there is no mileage break in your correct, I only change it to rid of excess debris after the first good ride
97grnrs is offline
post #5 of 6 Old 09-22-2018, 02:37 AM Thread Starter
Melampus's Avatar
SKYD <> Hi there, and thanks for jumping in! To clarify any ambiguity, I wasn't asking about a "clutch break-in period"; I was just asking if people are still changing their oil after the first 500 miles of new friction plates. I used to always do this - one & two decades ago - just like 97GR does, currently. The friction plates will often release some fiber as they break in so the oil change @500 miles was always just a preventative measure. I think I'm just going to change the filter bc my pockets are just too light to replace all that full synthetic. I should had used conventional when I changed the clutch, but I've been out-of-the-loop so long two steps ahead just slipped my mind.
97GR <> Thanks for the input. Nice to know I'm not the only one.
Melampus is offline
post #6 of 6 Old 09-22-2018, 05:15 AM
97grnrs's Avatar
Lots of people don't but like to keep my bikes top notch, better to be safe
97grnrs is offline
WTB 06 07 Engine / motor <<<<<<<<< NMBR1SPT Wanted: Buy or Trade 6 09-14-2013 06:55 PM
>>>>>2008 zx-10r - $6,300<<<<<< swing lo Bikes 4 Sale 12 07-14-2010 11:16 PM
Fellow ZX10 family... Need your support<<<<<<<<<<<< nbrion1 The Out House 25 01-22-2010 07:25 AM
