Gen 1: 2004-2005 clutch adjustment - Kawasaki ZX-10R.net
post #1 of 7 Old 07-15-2012, 01:25 AM Thread Starter
Heavyweight's Avatar
clutch adjustment
How do i do this properly???
Livin The Dream
Heavyweight is offline
post #2 of 7 Old 07-15-2012, 01:43 AM
ZXRANDY's Avatar
There is a knob on your clutch perch that the clutch cable runs through, you can adjust it there by turning the knob, as well as down where your clutch cable attaches to arm coming out of the clutch cover. You will see a section where the cable runs through a threaded rod with 2 nuts on each side.
ZXRANDY is offline
post #3 of 7 Old 07-16-2012, 11:40 AM
themightymezzo's Avatar
I believe there is a minimum gap required when you pull slightly on the clutch lever before the actual cable starts to disengage the clutch. If I remember correctly it's something like .??mm-??mm. This way when the lever is pulled it's completely disengaging the clutch and when it's released it's fully engaged.
I don't have my manual to post a link at the moment but you should be able to find it online.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #4 of 7 Old 07-16-2012, 01:20 PM
Slow Poke
bgmagma10's Avatar
Rule of thumb I'd fit at least a nickel width of slack as long as your clutch dis engages enough to get out of gear with your clutch lever pulled all the way in
bgmagma10 is offline
post #5 of 7 Old 07-16-2012, 01:22 PM
SkyDork's Avatar
As stated, the clutch adjuster is the threaded part in the clutch perch where the cable meets the lever. The threaded adjuster is used to take up the slack in the sheath to get rid of most of the freeplay.
You feel the freeplay in the lever as basically unrestricted movement of the lever before there is any tension on the lever. The easiest way to measure how much freeplay is in the system is to adjust the threaded until you can put the edge of a nickel in between the lever and the perch.
If there's not enough adjustment in the lever, then you'll have to use the jam nuts down at the clutch housing.
#WordCrimes
SkyDork is offline
post #6 of 7 Old 07-16-2012, 07:34 PM
zx racer's Avatar
you are correct sir... manual states you want 7-8mm of slack which is a nickel size between the clutch lever and perch if that helps the op.
05 ZX-10R SWB.
zx racer is offline
post #7 of 7 Old 07-17-2012, 10:19 PM Thread Starter
thanks for the reply guys
Livin The Dream
Gen 4: Clutch cable adjustment? Johnn999 Performance and Tech 5 06-27-2012 10:41 AM
04 636 clutch adjustment how to reckless1 ZX-6R & ZX-6RR Archives 3 03-05-2007 04:35 PM
clutch adjustment**UPDATE** norcal10 Performance and Tech 8 08-27-2006 09:33 AM
clutch adjustment bigsill Performance and Tech 14 07-14-2006 08:53 AM
Clutch cable adjustment BlackNinja The ZX-10R 1 05-18-2004 09:10 PM
