Gen 2: 2006-2007 Clock won't stay correct - Kawasaki ZX-10R.net
post #1 of 4 Old 11-05-2019, 07:16 PM Thread Starter
HoodieNinja636's Avatar
I have a 06 zx10r. I have no issues with the bike other than the clock won't keep the correct time. Anyone have any suggestions??
HoodieNinja636 is offline
post #2 of 4 Old 11-06-2019, 10:03 AM
SkyDork's Avatar
Are you sure that you're talking about the clock itself? And not the stop watch function?
The clock is completely internal to the cluster. If you're setting the correct time on it and it resets itself, then you have a power problem to the cluster or the cluster itself is damaged. You should monitor and troubleshoot it differently. Set the time on it so it's correct and check it again the next time you turn the key on. If it's correct, then check it again after you hit the starter button. The starter can be drawing the power too low for the clock to retain the time, or it's just losing power to it sitting around with the ignition switch off. There's not much to look at beyond checking the pins in the connector on the back of it or replacing the unit.
#WordCrimes
SkyDork is offline
post #3 of 4 Old 11-06-2019, 12:53 PM
Kawasaki Brad's Avatar
+1 Power problem.
Loose battery, loose battery connection, loose ground, weak battery, etc.
Kawasaki Brad is offline
post #4 of 4 Old 11-06-2019, 03:56 PM Thread Starter
I'm sure it's not the lap/timer function. I know the difference. Thank you though I will keep an eye on it. I figured maybe the battery was getting weaker and when i go to start it maybe it resets even though the bike itself still starts
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
07spec_ed
