clicking noise in front end - Kawasaki ZX-10R.net
post #1 of 7 Old 05-21-2007, 09:56 PM Thread Starter
jscho600rr's Avatar
i seen a post a couple of month back but i can not seam to find it
anyways when i load the front end of my 06 10 (for instance if doing a burn out)i hear a click and sometimes 2 i don't see anything moving but there oviousley is i was wondering if anyone else has had this and found it or if the guy that had this problem ever found and fixed it
thanks in advance
jason
jscho600rr is offline
post #2 of 7 Old 05-21-2007, 09:59 PM
bulletr1's Avatar
Send a message via Yahoo to bulletr1
Tighten the neck bearings. That should solve the problem but if not it maybe the head bearings going bad.
PC Frame, Swing Arm, Wheels. Gold Rear Sets, Chrome Heel Guards, Factory Pro. Vel. Stacks, PCIII, K&N Air Filter, Full Akra. Exhaust System, 525 DID Gold MVXZ Chain, HID KIT HI & LOW BEAM (6K), 1/5 Throttle Conversion, Ivan's Block Off Kit,TRE & Servo Elim. Air Box Mod, Stainless Steel Braided Lines, Blue Custom Gauge Panel, InterNatrix Paging Security Sys., Michelin Pilot Powers Tires, Barnett Clutch Springs, Custom In/Ex Cams by Web Cams, Milled Cylinder Head. 173.7RWHP
bulletr1 is offline
post #3 of 7 Old 05-22-2007, 06:22 PM Thread Starter
jscho600rr's Avatar
thanks man i'll try
i also hear it when i sat a wheelie down if that helps anyone else
post #4 of 7 Old 05-22-2007, 09:08 PM Thread Starter
jscho600rr's Avatar
checked and tightened the head bearings and it is still there i think i'm gonna tear the fairing's off and check for crack in frame
post #5 of 7 Old 05-22-2007, 09:49 PM
Images: 31
I have a clicking noise around my front end too. I mostly hear it when i back off the throttle a hair and when I pull in the clutch. I guess it does it when there is a slight load on the front. Any way I let the shop have it for a week and they couldnt figure out what it was and that it didnt seem to be messing anything up, and told me just ride it. I said ok but if anything happens it on them.
flank31791 is offline
post #6 of 7 Old 10-04-2007, 10:48 PM
FuTAnT's Avatar
Images: 7
I've got a similar problem with mine at the moment. I called the bike shop and they said they've had a few that require the stem adjustment at the 6000km mark. The damper tends to mask the effect, I could tell it straight up on my old '04 when it was getting a bit loose.
Anyhoo, make sure your stem bearings are correctly torqued then go from there. Remember, for the home mechs ... you have to tighten the two nuts *under* the top triple, not the big nut sitting on top. That's there just to hold the top triple on.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
'85 GSX250S -> '96 ZX6R -> '98 ZX6R -> '00 ZX6R -> '03 CBR954RR -> '04 ZX10R -> '02 ZZR250 -> '06 ZX10R -> '08 KTM 990 ADV
FuTAnT is offline
post #7 of 7 Old 10-04-2007, 10:52 PM
bkkninja's Avatar
I have seen this at first hand much to my horror, a mechanic getting a big mother of an air gun stick a socket on the top nut and pull the trigger on the gun and watch it rat a tat away for likes ages.... needless to say I bollocked him big time.
bkkninja is offline
Yes!!!!! I Fixed The "clicking" Noise onetoncj Performance and Tech 95 09-22-2011 07:55 AM
Front wheel squeaking noise? ZiG 9th The ZX-10R 22 11-12-2008 10:13 AM
Forks clicking!!!! Superbike1 Performance and Tech 6 06-05-2006 11:25 PM
front sprocket noise! Jedwin The ZX-10R 15 04-28-2006 05:10 PM
Whats the clicking?? Danezx10r The ZX-10R 9 07-07-2005 08:20 AM
