checking/adjusting valves ourselves? - Kawasaki ZX-10R.net
post #1 of 12 Old 12-22-2008, 04:20 PM Thread Starter
limegreenbloodz's Avatar
I was thinking about doing a valves job on my 14000miles 06 zx10(did 3 trackdays"beginner" and the rest is street)the bike feels ok,good power, I don't hear the valves ticking or anything it's just because if you look in the manual I'm suppose to have a valves job.is it too soon for a valves job?
is it really complicated to check/adjust the valve yourself?who are doing it themselves?
I prefer doing the mechanical myself,I never trust any stealership.when you do it yourself you know it's done right.
limegreenbloodz is offline
post #2 of 12 Old 12-22-2008, 04:26 PM
rocketracermike's Avatar
there been a few threads about this. use the search button and you have to track them down. a lot of people here have done there own.
rocketracermike is offline
post #3 of 12 Old 12-22-2008, 05:21 PM
I'm with ya on not letting the dealership do any work. I'll buy whatever tools I need to do whatever work I do. It's a good investment and like you say, at least it's done correctly.
Ingjr is offline
post #4 of 12 Old 12-22-2008, 05:52 PM
Nothing difficult, more attention to detail than anything. I would suggest a set of true valve type feeler gauges. These are the ones that have a little handle on each gauge. They make it much easier to get an accurate reading than a standard feeler gauge that tends to twist and bind. Also a good time to pick up an inch pound torque wrench if you don't already have one. The cheapo version is fine for the DIYer.
TN10R is offline
post #5 of 12 Old 12-22-2008, 09:29 PM
SpazOnaZX's Avatar
It's a lot of parts to remove, but it's all simple stuff. BTW, you won't ever hear valves get tight, which is what they usually do on the first check. If they get tight enough you'll eventally burn a seat, and by the time you notice it will be too late. It's really worth the effort to check them on schedule.
Cheers
SpazOnaZX is offline
post #6 of 12 Old 12-22-2008, 10:06 PM
ivyjohn865's Avatar
umm yeah, i wouldnt reccomend you do this by yourself unless you are entirely confident in what you are doing. I mean anyone can stick a feeler guage under a cam and measure tolerance, but if it comes down to auctually replacing a shim, then you are in for alot of work. If you get a valve (out of the 16) that is out of tolerance, then you have to take your camchain tensioner out, find a way to hold your cam chain in so that it dosent fall into your case, and then take your cams out, and be able to put them back in without changing the position that they were in even a single degree. Oh adn btw, make sure you are in TDC, and that you have a new valve cover gasket. Im telling you I do valves all the time man, its a rough job.
ivyjohn865 is offline
post #7 of 12 Old 12-22-2008, 10:09 PM
Mick1313's Avatar
Send a message via AIM to Mick1313
Im about to do my valves on my 04 zx10 and just invest in good feeler gauges and that torque wrench hands down, cause your gonna need it thats for sure, im adjusting mine at 10kmiles im at 9700 now so a couple of more gas tanks and everythings coming off and time for some new royal purp along with that those new valve shims.
Oh BTW you can mix and match up your valve shims and then just buy the ones you need, so save some extra money just my .02 cents
Mick1313 is offline
post #8 of 12 Old 12-23-2008, 10:08 AM
fireman69's Avatar
Hey guys, does anyone have a link to where I can find a "good" set of feeler gauges online? I have shopped all the usual spots and the gauges are all too wide. seems to me they are set up for automotive.
fireman69 is offline
post #9 of 12 Old 12-23-2008, 10:19 AM
ol_dog_big_balls's Avatar
Images: 9
Send a message via MSN to ol_dog_big_balls
If you got the know how go for it. It is not hard, just pay attention.
You always have the experience 3 seconds after you really needed it.
ol_dog_big_balls is offline
post #10 of 12 Old 12-23-2008, 12:48 PM
Try motion pro. Seems like I recall them making a set.
TN10R is offline
Checking the frame sonic397 The ZX-10R 21 06-06-2008 02:58 AM
Checking out for a while. FAF The Out House 11 08-14-2007 09:18 AM
Checking in BNninja The Out House 20 02-11-2006 08:45 AM
Checking... 1bad7 The ZX-10R 16 07-07-2004 04:26 AM
