Gen 2: 2006-2007 charging system - Kawasaki ZX-10R.net
post #1 of 10 Old 06-01-2011, 03:54 PM Thread Starter
jigger80's Avatar
charging system
I have an issue with the charge going back to the battery, it is very intermittent it will read above the 14.5 at the terminals but then drop back down below, it has a brand new regulator rectifier in, iv checked and no loose connections to be found, has any one ever had an issue like this? it's an 07 second gen, I'm kinda thinking startor myself, any input would be highly welcome!
jigger80 is offline
post #2 of 10 Old 06-01-2011, 03:56 PM
Speed Freak
garth285's Avatar
what is lowest voltage it drops to?
garth285 is offline
post #3 of 10 Old 06-01-2011, 04:14 PM Thread Starter
jigger80's Avatar
it's dropping down to 12is give or take, that's well below what's in the service manual but like I said it's very intermittent
jigger80 is offline
post #4 of 10 Old 06-01-2011, 07:29 PM
TexasRider's Avatar
How old is the battery
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #5 of 10 Old 06-02-2011, 01:34 AM
tasos's Avatar
Maybe it's old or misoperates?
tasos is offline
post #6 of 10 Old 06-02-2011, 03:14 AM Thread Starter
jigger80's Avatar
should have said the battery is brand new too
jigger80 is offline
post #7 of 10 Old 06-02-2011, 03:53 AM
The Nam3less's Avatar
what kind of accessories do you have running? anything staying on to drain it that you might know of?
only things i could think of. other than that it sounds like the stator. good luck
'11 Black zx-10r | Tech-spec Tank pad | Akraprovic w/ link | Power Commander V | Auto tune | HID | 1/5 Insert | Driven Smog Plates | DMP integrated tail light | Vortex rear sets w/ new pressure switch | Puig dark smoke windscreen | BMC Air Filter | Cox Radiator Guard |
To Do List:
ECU reflash
Steering Damper revalved
The Nam3less is offline
post #8 of 10 Old 06-02-2011, 06:36 AM Thread Starter
jigger80's Avatar
nope no accessories. TRE and pc3 are the only mods done to the bike.
jigger80 is offline
post #9 of 10 Old 06-02-2011, 06:51 AM
tasos's Avatar
If the battery and rectifier are new then..stator.
tasos is offline
post #10 of 10 Old 06-02-2011, 07:20 AM Thread Starter
jigger80's Avatar
turns out stator!! happy days....not!!
jigger80 is offline
Gen 2: charging system wetley Parts, Gear and Accessories 8 01-15-2012 08:05 PM
charging system ok? filthy phil The ZX-10R 4 12-14-2010 07:40 PM
charging system out? filthy phil Performance and Tech 11 10-08-2010 06:56 AM
Charging system problem performancezx10r The ZX-10R 1 09-11-2010 05:47 AM
charging??? Back in 10 Performance and Tech 2 01-09-2009 03:55 AM
