Changing swingarms questions - Kawasaki ZX-10R.net
post #1 of 3 Old 07-28-2010, 09:30 AM Thread Starter
latman's Avatar
How hard is it to change swingarms? I know I have to remove the rear suspension, tire, ect... Will I need any special tools? any special tricks, suggestions?
Right now I have my oem swingarm with extensions and replacing it with a oem swingarm. My swingarm with extensions, rear bracket that the brake caliper rest on was grind down so the wheel will not hit it.
Thanks for any help.
2004 Blazing Orange ZX-10R
latman is offline
post #2 of 3 Old 07-29-2010, 11:00 PM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
overall not hard, biggest thing is to supend the bike without worrying about it falling over.
I used a jack stand under each rearset (though i have aftermarket) this might not work with stock.
loosen all the bolts/nuts prior to lifting the bike.
as for the castle nut on the axle bolt, i have used a modded socket or one from cyclegear or even a tap and hammer to loosen it...
jdgun_13 is offline
post #3 of 3 Old 07-30-2010, 10:55 AM Thread Starter
latman's Avatar
Thanks Bro, That was the main thing I was worried about is tipping over. I was thinking about using some straps and suspending over a beam in the ceiling. I will have to check Cyclegear for that socket.
Thanks,
latman is offline
Gen3 swingarms dudewhrsmybike The ZX-10R 142 06-28-2019 01:10 AM
swingarms xtremest101 The ZX-10R 4 06-01-2009 10:25 PM
Swingarms 06green Strip 15 11-01-2006 10:45 AM
Extended swingarms..... JerseyKRS The Out House 8 08-12-2005 06:38 PM
Extended Swingarms ForceRecon Performance and Tech 7 01-01-2005 09:28 PM
