change my plugs a (FI)light is on. - Kawasaki ZX-10R.net
post #1 of 8 Old 04-22-2006, 06:24 PM Thread Starter
eric's Avatar
i change my plugs but the FI light is on and the bike is running like shit. i pulled 2 FI wires out last year and i recheck everything and its still on. i just ordered a new FI harness to try that out. anyone know any other reason it would be on and what to check. thanks.
eric is offline
post #2 of 8 Old 04-22-2006, 06:50 PM
Check all the electrical connections to the throttle body, I always seem to forget one. Check to see what code is set to give you a possible hint.
swjohnsey is offline
post #3 of 8 Old 04-22-2006, 08:47 PM
lavudyar's Avatar
Send a message via Skype™ to lavudyar
I forgot to plug in the airbox sensor last time, caused the same problem.
Ray D
Never pet a burning dog.
lavudyar is offline
post #4 of 8 Old 04-22-2006, 10:36 PM
Supercharged Mod
DON'T try to fix this by throwing random parts at it. That's the expensive and long way.
Scan it for codes (the shop manual explains how - the only tool required is a short piece of wire - a paper clip will do). THEN troubleshoot based on that code, as per shop manual.
Don't guess. You'll probably be barking up the wrong tree endlessly.
Seen it all before with cars ... this is not any different.
GoFaster is offline
post #5 of 8 Old 04-22-2006, 10:57 PM
Dragone's Avatar
Images: 11
hmm, sounds like the new putt putts are a pain in the ass to work on it seems. Good read though.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #6 of 8 Old 04-23-2006, 11:01 AM
Supercharged Mod
The only thing that's a pain in the ass is that everything is crammed into a very small space.
On-board diagnostics are a Very Good Thing. If the computer ain't happy, it can tell you why. But you have to make use of its capabilities ...
GoFaster is offline
post #7 of 8 Old 04-24-2006, 10:23 PM
Look for the small two wire plug back where the servo motor is for the ex valve you need to jump this with a paper clip to get the codes for the fi system to see what was left unplugged,jump it w/ the ign off and turn it on.if you don't know what or where take it to someone you trust.
hsmarc is offline
post #8 of 8 Old 04-25-2006, 12:39 AM Thread Starter
eric's Avatar
im going switch out the FI harness and see if that fixes it. if not then i will attempt to get a code. i have a feeling its the harness just because i have put on a mps fuel mix control and had to tap into the wires. well my buddy cut the wires way to short and i could barely get it hooked up so i need a harness so i can do it the way it was supposed to and not rigged up. i bought one on ebay for $19.00 which i thought was a steal. it should be here in a couple days and ill give you guys an update.thanks for all the info. i didnt know you could get a code like that. so thanks again.i learn something new everyday.
eric is offline
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
Help! I need how to change spark plugs gpz Welcome Newbies! 1 01-27-2006 12:19 PM
Change filter every time? mach_man_187 Performance and Tech 15 07-22-2005 05:24 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
