Chain or sprocket??? - Kawasaki ZX-10R.net
post #1 of 12 Old 06-12-2010, 07:57 PM Thread Starter
spence04's Avatar
Alright first off i have the 05 10r and i have the clicking issue coming from the front sprocket???? Y??? I done the whole putting it in 5th and rolling it back and popping the clutch thing and it didnt work......
My chain is keeps coming lose and i tighten it back up and i ride for ir for maybe a block and its lse again but the notches on the swingarm hasnt moved.
Do the notches have to be set on a notch and if so which 1 should it be set at...... Any help would be appreciated.
spence04 is offline
post #2 of 12 Old 06-12-2010, 08:24 PM
Justin's Avatar
How many Miles on the chain? My friends CBR 1000 was doing that and he had to replace the chain.
2004 ZX-10R - Powder coated Kawasaki green wheels, attack performance bars, PC III, Ivans GRE, vortex front sprocket, vortex cat 5 black rear sprocket, vortex rear sets, RK 525 green chain, galfer ss brake lines, custom frame sliders & and swing arm spools, BMC air filter, Scorpion street extreme exhaust, DB screen, Green integrated tail light kit, OEM seat cowl, speedohealer v4, Factory Pro velocity stacks.
Justin is offline
post #3 of 12 Old 06-12-2010, 08:26 PM
NinjeR's Avatar
There's probably a kink in your chain, it did a clicking sound on my black 10, it happened to be the chain
NinjeR is offline
post #4 of 12 Old 06-12-2010, 08:32 PM
sam_b03's Avatar
do you now how to check for proper slack in the chain?
http://www.canyonchasers.net/shop/generic/chain.php check out the link
The notches in the swingarm are just a point of reference for you so you can tell it the axle has slid and how much the chain has stretched. One way to tell if your chain is done. is see if there is slack on the rear of sprocket. If it is loose even when rapping around then it is time for a new chain and sprockets.
War is about killing people and breaking things. It ain't the olympics. Its not supposed to be fair. Tom Clancy
ialsodontknowwhynewpeoplecantseperatetheirthoghtss owecanreadthemitmakesitunweidlyandannoyingtryingto decipherwhattheyaretryingtosaysoiusuallyjustmoveon atleastyouusedpuncuationthoughsocongratsonthatbutm aybeinthefutureyoucanhelpusalloutbecauseyouoranyon eelsewillgetmorerepliesifyoudontwriteonebigrunonth atsimpossibletoread
sam_b03 is offline
post #5 of 12 Old 06-13-2010, 08:26 AM Thread Starter
spence04's Avatar
Hey thanks that was a great link about chain replacement i believe thats my next step......
But still could the notches on the swing have to match the notches on the adjustment block itself???
spence04 is offline
post #6 of 12 Old 06-13-2010, 08:35 AM
RDLYN13000's Avatar
Images: 38
I had the same problem with tightening my chain and having it loosen up right away and it ended up being a bad chain.
RDLYN13000 is offline
post #7 of 12 Old 06-13-2010, 03:24 PM Thread Starter
spence04's Avatar
Ok so what do you think about going with the 520 link chain or should i stick to the 525???
spence04 is offline
post #8 of 12 Old 06-13-2010, 03:39 PM
sam_b03's Avatar
The 520 is cheaper. A sponsor has a deal going err... did. good xring chain, and steel sprockets for 170. The rule of thumb is that the 520 will stretch a little faster than a 525 or 530 but is lighter so it is takes less power to turn. There are people that get 20K out of a 520 chain. It is all about maintains. No the pointer does not have to line up the hash makers on the on the swingarm. They are just a reference at to how much you moved the rear wheel and how much adjustment you have left. Adjust the chain so the tension is with spec tighten the wheel back down.
these are the marks you are talking about. correct?the marks on swingarm below the adjuster.
sam_b03 is offline
post #9 of 12 Old 06-13-2010, 04:53 PM Thread Starter
spence04's Avatar
Sam _b03 you are the man, i thought marks had to match but i will be switching to the 520 since i dont have to order 1, i can go to my local bike shop and they have plenty of them in stock.
spence04 is offline
post #10 of 12 Old 06-13-2010, 11:58 PM
BobFinnell's Avatar
If you switch to a 520 chain you have change the spockets too. 520 & 525 sprockets are different.
08 ZX-10r Lime Green | Full Akra | BMC street filter | Bazzaz Z-Fi W/map switch, Bazzaz Z-AFM | Secondary's Removed | GPR V4K | Scorpio i-900 | Wood Craft sliders | Roadlok disklock
BobFinnell is offline
Need chain/sprocket help. JUPJON The ZX-10R 19 07-15-2009 10:09 AM
Chain N Sprocket help !!!!!! Usmc2k Performance and Tech 26 10-23-2008 02:03 PM
OEM 2006-07 ZX10R Chain,front sprocket,rear sprocket, and Pirelli Dragon front tire Killerzxrider Parts, Gear and Accessories 0 09-26-2008 05:25 PM
chain and sprocket ????? 10R-rugger Performance and Tech 33 02-27-2008 07:07 AM
Need chain sprocket zx10Duran Vendors deals 2 07-11-2006 01:42 PM
