Chain Rivet tool question - Kawasaki ZX-10R.net
post #1 of 17 Old 04-16-2006, 12:09 AM Thread Starter
What brand of tool do you guys use to rivet a master link. I have a MotionPro and it's a peice of junk!! A $100 dollar POS!!!!!!!!!! I need a good one and quick.. What works for the most of you guys??
Gunner is offline
post #2 of 17 Old 04-16-2006, 12:27 AM
bluedevil's Avatar
Motion Pro makes a couple of versions...yes..junk to remove a link but I don't see a problem to press...for removal..a cheap grinder wheel on a drill and punch when it's hot...press part...have no problems with the MP.
bluedevil is offline
post #3 of 17 Old 04-16-2006, 12:30 AM
zeta xray's Avatar
I don't know if my Motion Pro is the same as yours or not. I think mine was more like $120, if I remember correctly. I have used it multiple times and I am very happy with it. I also have a friend who has used it a couple of times on his bikes and he thinks it is great.
Don't confuse me with facts, my mind is already made up.
zeta xray is offline
post #4 of 17 Old 04-16-2006, 12:39 AM
bluedevil's Avatar
not sure...but the pins to remove seem to be suspect on the motion pro...I don't mind using the grinder on a cordless drill and punch them out so the MP puches don't break as I have read many times they do and feel like they will when testing on the bench with some test pieces....they just don't seem strong enough for a 520 chain and above.
but not complaining...just need a press for the chain/master link...and it works...
post #5 of 17 Old 04-16-2006, 12:47 AM
Green Hippie
treyzx10r's Avatar
I got extra pins for mine 'cause I bent the first one seems okay now tho
VAE VICTUS!
treyzx10r is offline
post #6 of 17 Old 04-16-2006, 12:49 AM
Green Hippie
treyzx10r's Avatar
I use the same MP to install the master link I just drop a ground down bolt in the guide hole and instant press
VAE VICTUS!
post #7 of 17 Old 04-16-2006, 01:10 AM
bluedevil's Avatar
maybe we all are on a different page....the MP will press for me a master link 520 and above....taking a link out(breaking)...well....that's another thing....I believe it will break the MP punches most of the times as the chain links are stronger. ...still...think about it...what counts more... a link to be broken or a link that is pressed in good to save your arse?...just my .02...but make sure it is pressed good...lol...
post #8 of 17 Old 04-16-2006, 01:17 AM
Green Hippie
treyzx10r's Avatar
Hmmmm for sure a pressing issue
VAE VICTUS!
post #9 of 17 Old 04-16-2006, 01:20 AM
bluedevil's Avatar
lol fugger...
post #10 of 17 Old 04-16-2006, 05:51 AM
Ninjet's Avatar
This is the one I have. It works perfectly everytime and should last atleast one lifetime.
www.kowatools.com
JUST GREEN
Ninjet is offline
Question about chain adjustment lennyd96 Performance and Tech 16 09-27-2005 11:57 AM
Chain rivet question? VegasZX10R Performance and Tech 10 08-28-2005 07:16 AM
Chain/ sprocket question VegasZX10R Performance and Tech 50 08-13-2005 10:40 AM
Stock cam chain tensioner question! Superbike1 Performance and Tech 9 06-28-2005 03:58 PM
chain breaker tool help Andy Performance and Tech 14 04-06-2005 07:47 PM
