Gen 1: 2004-2005 chain length question - Kawasaki ZX-10R.net
post #1 of 20 Old 07-08-2012, 12:25 PM Thread Starter
I am planning to replace the chain on my 10r and thinking about putting +2 sprocket on the rear while keeping the stock one on the front.
My question would be whether the stock length (110) chain will fit that or I need a longer (112) link chain?
giszo is offline
post #2 of 20 Old 07-08-2012, 12:38 PM
Supercharged Mod
Either will work. Do you want wheelies, or do you want the bike to take off for the horizon?
Stock chain length will shorten wheelbase a little. That plus the extra gearing will make wheelies easier. Longer chain will help keep the front end down.
I've found that the Gen 1 can use the extra stability from a bit more wheelbase.
GoFaster is offline
post #3 of 20 Old 07-08-2012, 01:39 PM Thread Starter
The current setup on the bike that I bought it with is -1/+3. It is probably a little bit more than what I want/need. :)
Most of the time I am using the bike on street and 1-2 track days per month. I am not a person who wants to do wheelies so that is definitely not the goal. The reason why I thought about the +2 rear instead of the stock ratio is to get better acceleration while still keeping the bike streetable.
giszo is offline
post #4 of 20 Old 07-08-2012, 01:57 PM
blink.'s Avatar
Stock chain will fit.
blink. is offline
post #5 of 20 Old 07-08-2012, 04:45 PM
Post Whore
-Op-'s Avatar
It may fit, it may not. I could not get a 41 tooth to fit on stock chain and front sprocket on my Gen 1 though. It pulled it too far forward.
Edit: That was also after 15k miles
-Op- is offline
post #6 of 20 Old 07-08-2012, 05:18 PM
zx racer's Avatar
i tried a +2 on the rear with -1 on the front on my stock chain and it wouldnt fit so i had to go with 112 links to make it fit and it moved the axel back lil bit which was nice also.
05 ZX-10R SWB.
zx racer is offline
post #7 of 20 Old 07-09-2012, 01:31 AM Thread Starter
Do you know how much the rear axle will move back with the longer 112 link chain?
giszo is offline
post #8 of 20 Old 07-09-2012, 06:39 AM Thread Starter
In the meantime I called the shop I will order the chain from and currently they do not have the sprocket combination I was looking for, so instead of the +2 rear I am going with -1 on the front while keeping the stock 39 teeth rear sprocket.
With -1 on the front, the stock 110 length chain should fit without any trouble, am I right?
giszo is offline
post #9 of 20 Old 07-09-2012, 08:18 AM
zx racer's Avatar
with -1 +2 @112 links it moved the axel 3/4 back.
you be fine with -1 stock rear with 110 links.
05 ZX-10R SWB.
zx racer is offline
post #10 of 20 Old 07-09-2012, 10:29 AM Thread Starter
Thanks to all of you!
I will have the new chain and sprocket set tomorrow and hopefully I will have time to change it on the weekend.
giszo is offline
16T - 41T (- 1 + 2) New Chain Length muggz The ZX-10R 6 03-22-2011 02:27 PM
Chain length question ikaika Performance and Tech 9 08-24-2009 07:37 PM
Chain length with -1+2??? Blink180Wilhelm Performance and Tech 10 04-11-2008 10:43 AM
swing arm extensions (chain length question) vorderma Performance and Tech 2 04-20-2007 02:20 PM
chain length hollywood99 Performance and Tech 7 02-02-2007 10:14 AM
