Gen 3: 2008-2010 Chain help - Kawasaki ZX-10R.net
post #1 of 6 Old 05-04-2011, 09:34 PM Thread Starter
bluebeast10's Avatar
Chain help
Is it normal for the new chain to be 10 links longer than the old chain? Do I have to move the rear axle blocks up to the first notch on the swingarm? These may sound like stupid questions but this is my first chain and sprocket change
bluebeast10 is offline
post #2 of 6 Old 05-04-2011, 09:43 PM
Late Apex
Solo-Six's Avatar
Depends on the chain make ..but yes i almost always have to grind links off .. You can use a dremel and just chip away at the rivets or a cut off tool. Then theres always a chain break tool by motion pro . up to you really .. they are all equally simple .. Put the new chain on let it hang . position the axles a little past all the way tight to give yourself some lead way , line the link up to where you would cut off the chain . count the links and add 1 , cut off . install master link and your done. the add one accounts for the master link
FYI dont hack the center of the link on the new chain .. grind the rivets .. its ok if the face gets a little ground cause the master will replace it
________________Grip It And Rip It_________________
Solo-Six is offline
post #3 of 6 Old 05-04-2011, 09:44 PM
Gen2 Ripper
neverendingmods's Avatar
Usually the aftermarket chains are supplied longer so you cut to your own length needed. Cycle Gear has an awesome deal right now if you buy ANYTHING, you get the stockton tool chain kit for $30(reg $80 and what I paid). Has the cutter and all needed pins and presses to install the masterlink that CAME with your new chain.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #4 of 6 Old 05-04-2011, 09:49 PM Thread Starter
I have a EK-520 120 link. I already purchased the motion pro heavy duty chain breaker and rivet tool. What notch should I set the axle block? Somewhere in the middle or all the up to the first notch? Thanks for the help I really appreciate it
post #5 of 6 Old 05-04-2011, 10:01 PM
Gen2 Ripper
I set mine so that it's between the most forward and middle setting so as chain stretches it has plenty of room to adjust back.
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
post #6 of 6 Old 05-04-2011, 10:25 PM Thread Starter
Thanks
Drive Chain Swap Without Chain Tool muggz The ZX-10R 23 03-16-2011 04:25 PM
need a stock chain OR any 525 chain for this bike! mityaz Wanted: Buy or Trade 4 12-12-2009 11:19 PM
WANTED: Chain links or cheap stock chain Patrick Wanted: Buy or Trade 2 11-25-2009 10:57 AM
Chain Tensioner for 160 link chain. SAkI Wanted: Buy or Trade 0 10-13-2008 12:57 PM
help chain and sprockets which ones are the best also a chain breaker streetfighter Performance and Tech 19 11-09-2006 06:31 PM
