Gen 3: 2008-2010 chain came off when attempting a clutch wheelie...??? - Kawasaki ZX-10R.net
post #1 of 39 Old 05-12-2012, 12:36 PM Thread Starter
Ok so ive noticed when I do clutch up wheelies every now and then it would sound like a slight clink when I let out the clutch and it grabs wasn't sure if that was normal sounds of the clutch till now...I went to attempt a 4th gear clutch up and I got a clunk and the chain came off??!?! I pulled over and was able to easily roll the bike back on the chain and I'm thinking to myself this can't be right...how much chain slack an I supposed to have? With the bike at rest I can lift the lowers hanging point of the chain like 4 inches with my finger!! Is this normal? Also while down there I noticed my rear sprocket looks to be really close to my swingarm like the bolts/nuts on the sprocket actually look like they have been cumming into contact with my swingarm as there is a wear spot and even on my chain guard there's a wear spot from the chain that must be coming close... I took pic with my phone but don't know how to post them in here they're too big...?
C Murda is offline
post #2 of 39 Old 05-12-2012, 12:41 PM
Your chain is not supposed to have more than 1 1/2 in slack at the most. How many miles on your bike and how often did you clean/ adjust the chain?
enrico vespa is offline
post #3 of 39 Old 05-12-2012, 12:51 PM
Pictures of sprocket? And chain is WAY too loose. Tighten ASAP!!!!
Vortec is offline
post #4 of 39 Old 05-12-2012, 01:02 PM Thread Starter
I'm the second owner bought it with 4k now has 6k I had just cleaned the chain a few weeks ago but Im thinking it had this slack when I bought it but ya how do I post pics from my phone?? There looks to be a 1/4 inch gap between the actual rim and whatever it is the sprocket bolts to. If this is supposed to be inside of the wheel rather than sticking out a 1/4 inch then this may ne why my sprocket and chain are so rubbing
C Murda is offline
post #5 of 39 Old 05-12-2012, 03:04 PM Thread Starter
ok so i took off the wheel and the carrier just popped right off with no effort at all...im thinking it was pressed on all the way which was causing the 1/4 inch offset to the left ide making contact with my swingarm..anyways can some one please post up picture of what the spacers are supposed to look like on the carrier? i dont think this bike has the prober spacers or something is just wrong here..
C Murda is offline
post #6 of 39 Old 05-12-2012, 03:29 PM Thread Starter
i didnt realize how bad it was till i removed the wheel...i remember hearing a knocking at one point a while back and then it went away. must have been the bolts chewing away at the swingarm. also in the 1t and 2nd pic you can see the 1/4" gap of the carrier to the wheel
C Murda is offline
post #7 of 39 Old 05-12-2012, 04:59 PM
Boomer Sooner!
Bpcullen's Avatar
I don't really know a lot about that stuff, but I know that's not how it's supposed to look and I wouldn't be riding untill you get that fixed.
Bpcullen is offline
post #8 of 39 Old 05-12-2012, 05:00 PM
mreyna75's Avatar
Yeah...it looks like you're missing a spacer for sure, if not more(hard to tell from the pic)...here's the schematic http://www.bikebandit.com/houseofmot...48912sch582411 look at it and see what you're missing exactly
mreyna75 is offline
post #9 of 39 Old 05-12-2012, 09:07 PM Thread Starter
ok ive go the spacers and i think all those parts...it had just looked as if something was moved inwards too much of the carrier or im missing an "oil seal" on the chain side which i cant really tell what its supposed to look like all assembled :( either way i just bought a used complete carrier with sprocket off ebay for $35 cant loose there except for time!
C Murda is offline
post #10 of 39 Old 05-12-2012, 09:20 PM
lol at the metal shavings all over the wheel...you should have 3 total spacers one on each side of the wheel and then the one for the rear brake
seanc520 is offline
Clutch Wheelie Trouble - 2nd Gear kkieffer2003 General Motorcycle Discussions 54 03-14-2012 08:36 PM
Gen 3: Broken clutch after clutch-up wheelie. tvor The ZX-10R 12 11-02-2011 10:15 PM
clutch damage on wheelie... vr6 General Motorcycle Discussions 16 09-18-2009 09:53 PM
clutch wheelie appocalypse The Out House 10 08-19-2005 10:34 PM
Clutch Wheelie in 2nd = CRUNCH! bchild The ZX-10R 31 09-30-2004 11:19 AM
