carb sync question - Kawasaki ZX-10R.net
post #1 of 2 Old 06-24-2013, 07:53 PM Thread Starter
carb sync question
got the Motion pro carb tool and tried to sync my gen 1, I got 3 very close but I had to turn the screw out so far on one that I am afraid it will vibrate loose and fall out, these are the only screws that I can see to adjust and all were in all the way, am I doing something wrong ? I damn sure don't want to loose a screw during a race or I will be screwed for sure
felix1 is offline
post #2 of 2 Old 06-25-2013, 12:39 PM
I had a motion pro and it wasn't very accurate. I ended up buying a Morgan Carbtune Pro and it was more accurate and easier to use. Like the Motion Pro, the Carbtune has easy to see marks to get an even level of pressure. The only difference is the Carbtune has the vacuum pressure readings on it which allows you to have the right amount of vacuum pressure.
Sent from Motorcycle.com App
mathom33 is offline
sync question boothy 1963 Performance and Tech 2 04-23-2012 04:33 PM
Throttle Body Sync. Homemade sync tool pics biglipps66 Performance and Tech 2 04-26-2011 12:28 PM
MotionPro Sync Pro Carb Tuner BNIB edouble Parts, Gear and Accessories 8 02-17-2011 04:08 PM
WTB: Carb/TB Sync Tool; 4 cylinder SpazOnaZX Vendors deals 1 02-10-2009 10:10 AM
1998 ZX9R Valve Clearance, Carb sync. wingnut Performance and Tech 1 08-24-2008 09:28 PM
