Gen 1: 2004-2005 Can't remove engine mount bolt. Installing frame sliders. HELP! - Kawasaki ZX-10R.net
post #1 of 5 Old 06-09-2011, 09:17 PM Thread Starter
pjb84's Avatar
Arrow Can't remove engine mount bolt. Installing frame sliders. HELP!
I have the lightning performance frame sliders with the adapter that bolts into the top/rear engine mount.
The engine mount bolt is a 14mm and loosened up 1 or 2 turns fine, but after that it's turning REALLY HARD. Should I keep cranking on it? I don't want to break anything but feels like I will.
I've broken so many damn bolts in my life...trying to not break any on my zx10.
I tried retightening it and it won't tighen all the way now...giving me the same issues as when I was trying to take it off.
I feel like I need to lift up on the engine or something to remove some pressure.
Anyone had this issue?
Thanks!
-Peter
pjb84 is offline
post #2 of 5 Old 06-09-2011, 09:21 PM
Does not drive into smoke
El Zilcho's Avatar
It should come out without too much effort... Try spraying some liquid wrench on it.
Edit: Actually, if you feel that there is weight on that bolt, then putting support under the engine sure wouldn't hurt. There are two long bolts on which the engine hangs in the frame, so there is no risk that after removing the one you're talking about the engine will fall down or anything.
El Zilcho is offline
post #3 of 5 Old 06-09-2011, 09:26 PM
Gen 5 Now!!
08zx10rny's Avatar
should come pretty easy
GEN 5!!!
08zx10rny is offline
post #4 of 5 Old 06-09-2011, 09:49 PM Thread Starter
pjb84's Avatar
Thanks guys....you are awesome. I will try putting light pressure under the engine with a trolley jack and a 2x4 or something.
Will update after in case anyone else ever runs into this.
pjb84 is offline
post #5 of 5 Old 06-09-2011, 10:26 PM Thread Starter
pjb84's Avatar
UPDATE: Lubed it up nice, put some light pressure under the motor and turned.
The damn engine mount bolt broke off inside the bike. All I got in my hands now is the first inch or so. It broke off right where the threads begin...about 2 threads in. The entire threaded end is still in the bike.
I'm going to bring it to a local shop, hopefully they can drill it out. For how much...who knows.
pjb84 is offline
Engine Mount bolt removal, help livefreeordie10r The ZX-10R 3 07-18-2009 09:55 PM
brake side engine mount bolt tigersurvival The ZX-10R 1 07-03-2008 07:10 AM
Size of motor mount bolt/frame slider bolt? NYC_ZX10 ZX-6R & ZX-6RR Archives 2 11-26-2007 10:49 PM
Engine mount bolt problems KeepHerLit The ZX-10R 4 11-13-2004 06:11 PM
Installing frame sliders realestateguy The ZX-10R 4 08-23-2004 10:11 PM
