Can't adjust new clutch. - Kawasaki ZX-10R.net
post #1 of 17 Old 03-02-2011, 08:05 AM Thread Starter
Handle88's Avatar
Alright so I just put in a DP brand clutch in my '05. Followed the instructions in the service manual, everything lined up great. I can't seem to adjust it out to give it enough slack. It's adjusted as far as it will go and with the clutch lever pulled in when I put it in gear it still trys to pull forward. Any ideas or pointers? Help would be awesome, thanks.
Handle88 is offline
post #2 of 17 Old 03-02-2011, 11:31 AM
zx racer's Avatar
sounds like your clutch stack height isnt right.
zx racer is offline
post #3 of 17 Old 03-03-2011, 06:16 AM Thread Starter
Handle88's Avatar
Thats what someone was telling me about at work today. He said to look into getting some thinner steel plates. Am I heading down the right path with this? And got a good place to look for 'em?
Handle88 is offline
post #4 of 17 Old 03-03-2011, 06:36 AM
blink.'s Avatar
I've put new clutches in my 04 and never had a problem...Is this your first clutch change?
blink. is offline
post #5 of 17 Old 03-03-2011, 07:13 AM
codyc_13's Avatar
Are you adjusting at the lever or down by the clutch cover? The lever adjuster is just for fine tuning, you start with the clutch cover then when you get it close use the lever adjuster
codyc_13 is offline
post #6 of 17 Old 03-03-2011, 09:05 PM Thread Starter
Handle88's Avatar
This is my first clutch change on this bike. The first time I changed one was on a '09 gsxr 750 and it went flawlessly. And yea, i adjust it at the clutch cover first, you know, pull the cable forward till its tight and tighten the adjusting nuts, then try to fine tune it up at the clutch lever. My problem is that i've got no more room on the adjustment at either end now. The only thing I could come up with is that maybe since the new friction plates aren't worn like the old ones that they're gonna be a little thicker but still, aside from slipping under hard acceleration my old clutch worked right and still had room for adjustment. I've taken the cover off and checked to make sure I have everything lined up right, double checked myself, everything. I had to step back for a minute cuz this is getting frustrating. Any help is good help at this point. Thanks guys.
Handle88 is offline
post #7 of 17 Old 03-03-2011, 09:42 PM
Certified SLOW
nolaZX10's Avatar
:iamwithst
nolaZX10 is offline
post #8 of 17 Old 03-03-2011, 09:47 PM
Judge Dredd Mod
mr_honez's Avatar
BURNOUT.....
mr_honez is offline
post #9 of 17 Old 03-03-2011, 10:29 PM Thread Starter
Handle88's Avatar
Alright so I am with you guys on the stack height. So whats next? I'm learning all this as I go and trying to learn as much as possible. \
Handle88 is offline
post #10 of 17 Old 03-03-2011, 10:29 PM
count the old plates. make sure you didnt slip one of the old ones in there too.
mityaz is offline
Valve Adjust for 04 10r? bluedevil Performance and Tech 9 05-21-2009 01:12 PM
how to adjust the clutch codyc_13 Performance and Tech 3 06-14-2008 01:53 PM
how to adjust the idle codyc_13 The ZX-10R 19 03-03-2008 10:33 PM
How do you adjust the slipper clutch? OmegaX Performance and Tech 3 05-03-2007 01:30 AM
Valve Adjust swjohnsey Performance and Tech 6 07-29-2005 08:39 PM
