Can this be welded? - Kawasaki ZX-10R.net
post #1 of 8 Old 03-31-2008, 09:10 PM Thread Starter
Can this be welded?
Broke bottom corner of frame by the shifter. Can this be welded? Does any one if this can be fixed? And what is this frame made of? It's an 05 ZZR 600.
predator is offline
post #2 of 8 Old 03-31-2008, 09:13 PM
rocketracermike's Avatar
i why not if you can find a good welder. the only problem i see. theres no way the welder can get behind it to weld the other side.
rocketracermike is offline
post #3 of 8 Old 03-31-2008, 09:24 PM Thread Starter
Yea, I am afraid I will have to take the whole bike apart. I Don't want to, but if I have no choice, then I guess I have to.
predator is offline
post #4 of 8 Old 03-31-2008, 10:42 PM
sextaafondo's Avatar
Removing rear susp and swingarm may be enough. Show it to the welder
sextaafondo is offline
post #5 of 8 Old 03-31-2008, 11:05 PM
redline659's Avatar
yeap, that can be fixed
redline659 is offline
post #6 of 8 Old 04-01-2008, 05:49 AM
jrbard's Avatar
It can be welded. It looks like white metal. Make sure the welder is good. He will probably add another piece in there also. That crap is very brittle once it is heated. I don't know how it broke in the first place but you best not do it again once it is fixed cause it will break again.
jrbard is offline
post #7 of 8 Old 04-01-2008, 09:54 AM
redline659's Avatar
By the looks of it, it got hit or dropped HARD.... The whole damn rear set broke off
post #8 of 8 Old 04-01-2008, 12:28 PM
Retired post whore
Alien10's Avatar
I think a skilled welder would have no problem fixing that up with a TIG welder.
Alien10 is offline
ZX10r 8" stretched stock swingarm cut and welded!!!! must go!!!! garth285 Parts, Gear and Accessories 9 09-30-2007 09:24 PM
Is the Oil Filter on the 06 welded! ZX10RHulk Performance and Tech 47 02-21-2007 04:21 PM
Welded up the slipper clutch DethsZX10 Performance and Tech 15 10-17-2005 09:45 PM
