can any one help a brit out with porting info???? - Kawasaki ZX-10R.net
post #1 of 16 Old 01-20-2010, 03:13 PM Thread Starter
hi
I cant find info im after in the uk so hope you guys can help out,
sorry if its been asked before.
ok im just in the process of stripping and rebuilding my race bike (zx10r 06)
what i need to know is when porting the head is it best to make the ports as big as poss or just stick with keeping them as they are and just matching them (size)
also if i go bigger how big?
thanks in advance
24-7racebikebitz is offline
post #2 of 16 Old 01-20-2010, 03:43 PM
you actually want to get them smaller. do a search, there are some info on this. i think garth is the one you should talk to
mityaz is offline
post #3 of 16 Old 01-20-2010, 03:45 PM
Funshine Bear
minichevy's Avatar
Location: Back on the road again. Auto club speedway is my new home.
Send a message via MSN to minichevy
Garth is not here anymore.
If you ain't first, your last!
Thats a registered trade mark of Rick Bobby INC.
minichevy is offline
post #4 of 16 Old 01-20-2010, 03:46 PM
10 ninja r's Avatar
Originally Posted by minichevy View Post
garth is not here anymore.
wtf ?
06 zx-10r MPS nos kit (40 dry)NOS mini controller , Brocks ex (Full undertail system) Piper cross (Air filter) PowerCommander 111 HUB and Quickshifter Carrozzeria v-star rims(HPC map and tune) 2011 zx-10r Austin vr 250 mm pipe, Guhl reflash, bazzaz self map w/ quick shifter, Bmc carbon race filter,attack rear sets,driven sprockets -1/+1 OZ racing wheels. Special Thx GUHL MOTORS,HOUSE OF SPEED 2011 lexus is-f
10 ninja r is offline
post #5 of 16 Old 01-20-2010, 03:54 PM Thread Starter
smaller? i`v searched the forum but still dont get it!!
post #6 of 16 Old 01-20-2010, 03:56 PM
dsabat's Avatar
If you are doing it yourself, keep the shape and general size, and smooth out all surfaces, including unshrouding the valves. Look at the race manual, the process is described there. Get a good valvejob, install stiffer springs, and you're good to go.
dsabat is offline
post #7 of 16 Old 01-20-2010, 04:02 PM Thread Starter
this is why im confused , everyone in the uk tells me to stick with stock valve springs and valves.
I`v manged to get a thin head gasket so was just hoping to tidy the head up enough to get at least 180bhp
post #8 of 16 Old 01-20-2010, 04:14 PM
Like was mentioned before, if u are doing them yourself just clean them up a bit. If u are going to have them done there are pro's out there who actually make the ports smaller to maximise velocity. I read of this on one of Garths threads (wish he was still around....). They were claiming around 10hp gain.
Scott10r is offline
post #9 of 16 Old 01-20-2010, 10:10 PM
dsabat's Avatar
Most pro porters (Carpenter, KWS, Lee Shierts, Lazer, Comp CNC) will open up the port volume. The reduced choke velocity port is an alternate, less common method. I picked up 8hp with mild porting, a race cam, 14:1 CR, and .026" squish. I have a small-port head now on my turbo, built by Ryan Kallina, but haven't tested it back-to-back yet. The stock valves are fine for normally aspirated motors. Swap out the Ti ex valves for turbo or heavy nitrous use, too much heat.
If you plan to use the motor at high rpm ranges, I would highly suggest a set of stiffer valve springs. Not only will the head perform better with more accurate valve closing, but you will help to prevent valve spring retainer failure. The Carpenter 62lb single springs are $150 from Schnitz Racing. The APEs are a bit lighter weight, double spring, and around the same price from APE.
dsabat is offline
post #10 of 16 Old 01-21-2010, 05:19 AM
mr747's Avatar
calling garth calling garth
FULLY LOADED :)
mr747 is offline
Brit Superbike results Zed Race and Stunt 3 08-16-2004 01:52 AM
Brit Superbikes - Hawk Kawasaki does it again!! Zed The ZX-10R 5 07-18-2004 01:54 PM
Hawk Kawasaki win in Brit Superbike!! Zed The ZX-10R 5 07-05-2004 12:21 AM
Brit Superbike - Hawk's Progress Zed The ZX-10R 5 06-06-2004 10:52 AM
Brit Superbike ZX10's match Silverstone lap record Zed The ZX-10R 7 03-28-2004 03:41 AM
