Camshaft swap. - Kawasaki ZX-10R.net
post #1 of 12 Old 08-25-2010, 04:41 PM Thread Starter
Camshaft swap.
Hello; Mike here. I have an 04 with the 08 race intake cam installed. I am getting some head work done, and was thinking about moving the original 04 intake cam to the exhaust side for the additional lift, and duration. I was wondering if this is worth bothering to do? Has anybody done this and seen a gain? I know that several people have done it. Does anybody have any pics of how they modified the intake cam to signal the cam sensor? Any help would be greatly appreciated. Thanks. Mike.
880turbo is offline
post #2 of 12 Old 08-25-2010, 05:02 PM
Speed Freak
garth285's Avatar
I have done it, I saw about half a horsepower gain in the midrange and that was about it, the cams are made out of very strong metal so you better have a press and a box of drill bits to drill the hole in it.
I couldn't;t suggest running it, not worth the effort in my opinion. just my
garth285 is offline
post #3 of 12 Old 08-26-2010, 11:58 PM
zx-sik-r's Avatar
i did it and it works great...however i wouldnt drill the cam wich there is no reason to.a "collar"of sorts needs to be welded on to it...and yes its heat treated so its a bitch.a very good machinist can do do this for you....and the amount of hp you gain depends on your overall package.im gona have mine tuned by Walter Sprout next week...ill post results
zx-sik-r is offline
post #4 of 12 Old 08-26-2010, 11:59 PM
Speed Freak
garth285's Avatar
tell Sprout I said whats up!
garth285 is offline
post #5 of 12 Old 08-27-2010, 07:59 AM Thread Starter
camshaft swap.
Thanks for the reply's. Please keep me updated with your dyno numbers. I also know Walter Sprout. Did you take any pics of how the cam was modified? I think this could be a good mod for a lot of people since they allready have the kawasaki race intake cam, which means they can take their stock intake cam and move it to the exhaust side. I was thinking of a small piece that would clamp on to the cam, but it could certainly be welded. Mike.
880turbo is offline
post #6 of 12 Old 08-27-2010, 07:03 PM
zx-sik-r's Avatar
no pics,i wish i would have cause he did such a good job.the cams will need to be indexed to get this right i took him the exh and in to get this right...if your a cunt hair off it wont run...the timing will be too early or too late.the welding will def warp the cam also but my guy spent more time gettin mine back straight then he did the whole job
zx-sik-r is offline
post #7 of 12 Old 08-30-2010, 08:12 AM Thread Starter
camshaft swap.
Did the piece that was welded on to the cam exactly like the original Bump? Does it have to have the same sharp squared of edge? What did the guy charge you to do the cam mod? I would definately like to do this when I install my head. Thanks. Mike.
880turbo is offline
post #8 of 12 Old 08-30-2010, 09:37 AM
Speed Freak
garth285's Avatar
make sure you do back to back runs to see your results
garth285 is offline
post #9 of 12 Old 08-30-2010, 10:48 AM
dsabat's Avatar
Yep, this applies to cylinder heads too.
dsabat is offline
post #10 of 12 Old 08-30-2010, 11:02 AM
Speed Freak
garth285's Avatar
:iamwithst
garth285 is offline
Camshaft Timing flashf3 Performance and Tech 5 05-12-2010 11:54 AM
Another swingarm swap question... 1st gen to 2nd gen swap RITCHYRITCH The ZX-10R 2 10-21-2009 04:05 PM
won a race camshaft! bodymanruss518 Performance and Tech 13 02-26-2008 10:58 AM
should I swap to a 06-07 race tail along with my front end swap? garth285 The ZX-10R 10 12-05-2007 10:21 PM
Camshaft Supplier browserzx10 Performance and Tech 6 09-17-2007 09:48 PM
