cams question - Kawasaki ZX-10R.net
post #1 of 8 Old 11-14-2007, 06:32 PM Thread Starter
bodyglove's Avatar
Images: 15
Send a message via MSN to bodyglove
cams question
when installing the new intake race cam do you have to get new shims to adjust them , or does'nt need adjustment , and just leave the old shims in place
bodyglove is offline
post #2 of 8 Old 11-14-2007, 06:48 PM
Speed Freak
garth285's Avatar
well all depends on how they are to begin with, the cam specs might be slightly different.... half the time they check out to be ok but its always in the best interest to check clearances and re-shim if needed.
garth285 is offline
post #3 of 8 Old 11-14-2007, 06:51 PM
10rmotor's Avatar
You need to check the valve clearances after any cam is installed - doesn't matter if its stock or race. If they are not in spec, the cam gets removed and the shims swapped out with different thickness shims, and the process is repeated until all the clearances are good.
10rmotor is offline
post #4 of 8 Old 11-14-2007, 06:52 PM
Dragone's Avatar
Images: 11
Since it is opened up, just do a check before buttoning things up.
Dragone is offline
post #5 of 8 Old 11-14-2007, 06:53 PM
Speed Freak
garth285's Avatar
the manual has step by step instructions if doing this your self.... you basically measure how loose they are and find out what spec is and look to see what size shim is in there and go up to what ever size needed to make the clearance in spec.... they have a nice lil chart in the manual.
garth285 is offline
post #6 of 8 Old 11-14-2007, 08:18 PM Thread Starter
bodyglove's Avatar
Images: 15
ok thanks for the advice .
post #7 of 8 Old 11-14-2007, 09:03 PM
jimbob8915's Avatar
Dont try to degree your cams untill all your valve clearances are good.
jimbob8915 is offline
post #8 of 8 Old 11-14-2007, 09:31 PM
logmaster's Avatar
What type of gains can be expected with a race intake cam?
(too tired right now to search )
logmaster is offline
06 cams in an 04/05? 10rmotor Performance and Tech 7 07-23-2007 08:20 PM
06 cams? ninjasuz The ZX-10R 8 02-08-2007 01:01 PM
2000 zx9r cams vs. 1999 zx9r cams jrc0210 ZX-9R Discussion 2 12-20-2006 11:08 AM
Where to buy cams for 06 tru194 Performance and Tech 8 06-05-2006 02:43 PM
Cams 96dragshee Performance and Tech 14 10-30-2004 03:04 PM
