Gen 1: 2004-2005 Cams - Kawasaki ZX-10R.net
post #1 of 5 Old 01-13-2019, 01:17 PM Thread Starter
Kawigreen05ZX10's Avatar
Cams
I'm about to rebuild my motor. Need opinions on which cams to do. Gen 3 intake for my exhaust? New web cams? Any advice and build opinions would be greatly appreciated!
Kawigreen05ZX10 is offline
post #2 of 5 Old 01-13-2019, 03:08 PM
michael4012's Avatar
There'll be a guy coming over shortly to tell you all about the G3 intake and stock G1 exhaust combination,Gaz knows how to build those G1 & 2's real fast.
michael4012 is offline
post #3 of 5 Old 01-14-2019, 07:48 AM
gaz
gen 3 stk int/stk gen 1 ex cam will add power and decent budget mod. gen 3 race int or gen 1 race int will make more, still stk ex cam. only web cams i suggest stk piston bike is small stk lift web reground/reprofiled original cams. made more power with these than any other web cams on stk piston motor, more than the larger webs and ive used them all except the 384 lift. important since ur rebuilding to do performance head mods along with int cam to make good power. cam alone will make very little, supporting head mods alone will make more hp/torque than just throwing cam in stk top end. good competition valve job, .015-.020 mill, .45 mm hg alone w give u 10+ hp with good increase in torque. now u add camshaft and it will make the power it was designed to make. well ported head always beneficial but adds cost. few realize that vj/mill/thin hg account for half the hp increase alone from a built ported head. best bang for buck gen 3 stk int, mill, vj, thin hg. porting another 10 hp but $$$. to finish u need good hp exhaust, cams degreed correctley and tune, where many fall far short in becoming fast.
gaz is offline
post #4 of 5 Old 01-14-2019, 08:19 AM
gaz
read ur previous posts, saw where u thought u had retainer/keeper problem, but found no problem and decided spun bearing instead? spun bearing will always show up with gold colored metal in oilpan. before u go ripping that whole motor apart, drain the oil/pull the oil pan and inspect both. no gold colored metal flakes, no bottom end problem and no wasted money/effort.spun main or rod bearing will have a lot. just a few tiny specs usually present from clutch plates.
gaz is offline
post #5 of 5 Old 01-25-2019, 06:33 PM Thread Starter
The oil pan was already off when I picked the bike up unfortunately.
2000 zx9r cams vs. 1999 zx9r cams jrc0210 ZX-9R Discussion 2 12-20-2006 10:08 AM
Pistons & Cams jburmeister Performance and Tech 17 03-08-2005 02:30 PM
Anybody make cams yet sweetride10r Performance and Tech 23 12-31-2004 02:10 AM
Cams 96dragshee Performance and Tech 14 10-30-2004 02:04 PM
Aftermarket Cams hillcountry10r Performance and Tech 23 08-30-2004 02:21 PM
