Gen 4: 2011-2015 Cam Timing - Kawasaki ZX-10R.net
post #1 of 6 Old 08-04-2014, 09:45 AM Thread Starter
kman0066's Avatar
Cam Timing
I'm putting my '11 ZX-10R engine back together after getting the head decked (0.012"), a valve job, as well as a 0.50mm kit head gasket. I decided to measure the cam timing with the stock sprocket holes first to see if I was close enough to not have to bother with the elongated holes. Stock cams BTW.
Here is what I have: 113.5/103.75
Kawasaki recommended numbers: 112/104
Piston to valve clearance is fine.
Think that's ok to go with? At this point, taking the sprockets off to put them on the elongated holes is a PITA, and then I can't fit a wrench in there to adjust them with the engine in the bike, so I'd either had to pull the cams each time to adjust or drop the motor.
So, the question is, live with 113.5/103.75 instead of 112/104, or spend hours adjusting to 112/104 exactly? The exhaust cam is obviously close enough, but the intake is 1.5 degrees off...and I don't know enough about cam timing to know if that will have a profound negative effect on power or not.
Thoughts? What is the effect on the power curve with the intake cam timed 1.5 degree higher?
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
post #2 of 6 Old 08-04-2014, 12:19 PM
Supercharged Mod
I doubt if you would ever notice the difference.
GoFaster is offline
post #3 of 6 Old 08-04-2014, 08:51 PM
badassjake's Avatar
button it up and carry on. :)
badassjake is offline
post #4 of 6 Old 08-05-2014, 03:52 PM
gazx10's Avatar
compression increase from hg/deck are good hp mods and increased cyl. pressure will support the int. cam # u have. road race bike? rev limit? i would bump the ex. cam up 3-4 degrees.
gazx10 is offline
post #5 of 6 Old 08-05-2014, 04:05 PM Thread Starter
kman0066's Avatar
Yep, dedicated road race bike, rev limit raised +500 rpm with the race ECU. I think I will bump up the exhaust cam. You're the second person to recommend that to me now. The good news is that I can get to the exhaust cam sprocket so I can adjust that one with the engine & cams in the bike. The exhaust valve was JUST at the limit for clearance, so a little extra wouldn't hurt. Thanks for the advice.
So, going to set at 113.5/107, leaving the intake alone.
WERA Expert #43
kman0066 is offline
post #6 of 6 Old 08-05-2014, 05:00 PM
Joel's Avatar
Keep us posted
Joel is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Battlax Bunny
Gen 1: looking for some cam timing advice felix1 Performance and Tech 5 03-10-2014 09:39 PM
Intake cam timing??? Quantrill Performance and Tech 0 06-21-2012 09:20 PM
kit cam timing tails k6 Performance and Tech 13 02-28-2012 08:05 AM
Cam timing browserzx10 Performance and Tech 9 09-26-2007 11:38 AM
Degree cam timing and why. otto Performance and Tech 27 04-02-2006 09:16 PM
