Cam questions - Kawasaki ZX-10R.net
post #1 of 12 Old 10-16-2007, 03:04 PM Thread Starter
eazy_zxrr's Avatar
Cam questions
does anyone have the kawi race cams on there 06/07? and if so how do feel bout them? and did you have them degreed? how much was gained hps, torgue an dyno graph if dont mind i want to see curve? and what other mods where done with? im asking cause im really want to get them but no one around me has them or worked with them to give any feed back, so as much feed back i can get will be appreciated!!...
eazy_zxrr is offline
post #2 of 12 Old 10-16-2007, 05:01 PM
FAF
Rent this space
A lot of people have done the intake cam and not the exhaust , the exhaust cam has lower numbers which leads me to believe it needs more RPM's and a tuned exhaust.
FAF is offline
post #3 of 12 Old 10-16-2007, 05:47 PM
Ex Postwhore
9520G's Avatar
Send a message via MSN to 9520G
What do you exactlymean by "tuned" exhuast?
9520G is offline
post #4 of 12 Old 10-16-2007, 06:00 PM Thread Starter
eazy_zxrr's Avatar
yeah can you explain what you mean by tune exhaust?
post #5 of 12 Old 10-16-2007, 06:15 PM
FAF
Rent this space
A proper tuned length to control pulse waves and extraction.
FAF is offline
post #6 of 12 Old 10-16-2007, 06:45 PM Thread Starter
eazy_zxrr's Avatar
so you dont think full akrapovics wont work well with both cams? or are talking bout a good custom map? i still dont understand what you mean...
post #7 of 12 Old 10-16-2007, 07:09 PM
FAF
Rent this space
I couldnt really tell you without testing them personally, but several guys on here have found the exhaust cam to be inadequate.
By having a tuned exhaust diameter and length can help extract exhaust gases more efficiently and allow you to use smaller valves or less valve lift, there are several reasons for doing this , and to put it simply the less exhaust gases that get blown back into the engine the more efficient it is and the less fuel expended without burning going through the exhaust also means better efficiency. Its a little more complex than I stated but it may give you an idea.
By cutting down on the time that the exhaust valve is open reduces the amount of wasted fuel and also reduces burnt gases re entering the engine, but it has to be big enough and open enough to do the job.
Without physically testing the exhaust cam it is hard to determine wether it is an improvement or not but others have tried it and seen no gains in power , where it may help is in power delivery and better throttle response.
Garth has tried the exhaust cam and found no improvement on the dyno.
FAF is offline
post #8 of 12 Old 10-16-2007, 07:23 PM Thread Starter
eazy_zxrr's Avatar
better power delivery and throttle response is worth it... but i would gain power from the intake cam or are you just saying just do intake cam?
post #9 of 12 Old 10-16-2007, 07:24 PM
FAF
Rent this space
I would just do the intake cam, theres a lot of info on this site about the setup.
FAF is offline
post #10 of 12 Old 10-16-2007, 07:26 PM Thread Starter
eazy_zxrr's Avatar
do you happen to remember what post the info was on?
A few questions ???? fsr154 Performance and Tech 1 03-10-2007 08:46 PM
Hi and questions 01001010 ZX-7, ZX-7R & ZX-7RR Discussion 5 05-17-2006 05:23 PM
A few questions....... Devilrides__25 Performance and Tech 9 01-26-2006 09:18 AM
Saying hello and a few questions stkr02 The Out House 11 06-22-2005 02:00 AM
MMI questions... gunit0217 The Out House 5 01-09-2005 12:33 PM
