Cam Degree?? - Kawasaki ZX-10R.net
post #1 of 12 Old 03-29-2006, 07:17 PM Thread Starter
bragg10r's Avatar
Cam Degree??
Was wondering how much HP/TQ i would gain if I did this mod? I'm into drag racing and I need more TQ then HP........ What are the best mods to improve the TQ of the 10R???
"Best" (Time Slip Proof) Run so far :
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #2 of 12 Old 03-30-2006, 01:37 AM
Send a message via AIM to Cycle Concepts
degreeing the cams don't really gain hp but merely moves your power curve around alittle...if you want more hp/tq for drag racing, you're gonna have to crack it open and do some engine work...3mil, head/cams,etc...190-195 realisticly...everyday rideable also...give us a call if interested..803.285.8093
dwayne
Cycle Concepts is offline
post #3 of 12 Old 03-30-2006, 10:41 AM
Post Whore
1killer1liter's Avatar
Images: 11
Just degreeing the cams will net you 2-5 hp.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #4 of 12 Old 03-30-2006, 07:37 PM
Granted if the cams are off a mile you can see a gain from degreeing, BUT usually all you see is the power band moved up or down the rev range. Cam timing is determined by what you're going to be doing with the motor. A road racer will need his power in a certain spot and a drag racer another, and a hill climber another. It also depends on the camshaft in question. a big cam may need a little more advance to help the bottom end some. While a smaller cam may like to be retarded to help it work better on the top. It's all about trade offs. Give here and get there. If you're seeing 5 or so HP from degreeing I'll bet if you compare grafts you'll probably see it missing from some other spot in the rev range.
Gunner is offline
post #5 of 12 Old 03-30-2006, 08:00 PM
Originally Posted by Gunner
Granted if the cams are off a mile you can see a gain from degreeing, BUT usually all you see is the power band moved up or down the rev range. Cam timing is determined by what you're going to be doing with the motor. A road racer will need his power in a certain spot and a drag racer another, and a hill climber another. It also depends on the camshaft in question. a big cam may need a little more advance to help the bottom end some help while a smaller cam may like to be retarded to help it work better on the top. It's all about trade offs. Give here and get there. If you're seeing 5 or so HP from degreeing I'll bet if you compare grafts you'll probably see it missing from some other spot in the rev range.
Dreadnought-arr is offline
post #6 of 12 Old 03-30-2006, 08:39 PM Thread Starter
bragg10r's Avatar
dwayne
I'll give you a call.....Thanks
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #7 of 12 Old 03-30-2006, 09:11 PM
Post Whore
Images: 11
I called muzzys and that is what they told me. I do agree that changing cam timing will move the power the powerband.
post #8 of 12 Old 03-30-2006, 10:12 PM
speed4life's Avatar
Images: 7
Just throw the Juice to tha bitch and tune it for such application
SPEED4LIFE
speed4life is offline
post #9 of 12 Old 03-31-2006, 11:55 AM
gabe's Avatar
has anyone tried the cams that kalwasaki is selling? The intake cam
gabe is offline
post #10 of 12 Old 03-31-2006, 01:24 PM
Post Whore
Images: 11
There are a few members here that have the race intake cam. Do a search.
Degree cam timing and why. otto Performance and Tech 27 04-02-2006 09:16 PM
Kawasaki H.P. intake cam max-out Performance and Tech 58 07-06-2005 05:16 PM
Info on gasket change and cam degree in frame?? on1whl Performance and Tech 5 05-01-2005 04:42 AM
Gasket and Cam Install BNninja How To... 42 04-08-2005 09:55 AM
Cam Degreeing Question !!! Bobster Performance and Tech 7 04-05-2005 03:15 PM
