Cam chain tensioner ques. Not zx10r related - Kawasaki ZX-10R.net
post #1 of 10 Old 10-18-2014, 09:00 PM Thread Starter
rosemont83's Avatar
I'm trying to help a buddy with his 2002 yamaha r1.
It vibrates A LOT. I think it's his cam chain tensioner.
He has 40K on the odometer and looks like the previous owner put a manual cam chain tensioner that my friend hasn't touched for the 13K miles he's owned it.
Does anyone know how to adjust this thing?
rosemont83 is offline
post #2 of 10 Old 10-18-2014, 10:24 PM
Teeks's Avatar
INSTRUCTIONS
To set the tensioner adjustment, rotate the engine forward while screwing the tensioner bolt in. When you feel the engine tensioner parts (guide, rollers, etc.) make contact with the moving cam chain, back the tensioner bolt out 1/4 turn and tighten the jam nut. (For the finer pitch thread on the APE Pro Series tensioner it is advised to back the tensioner up 1/2 of a turn.)
DO NOT over-tighten the cam chain, as cam chain giude damage could occur. Be sure jam nut is tight against the tensioner body when complete.
This is per APE's website.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 10 Old 10-18-2014, 10:50 PM Thread Starter
rosemont83's Avatar
So I rotate the crankshaft clockwise using a wrench while turning the screw clockwise as well right?
post #4 of 10 Old 10-18-2014, 11:09 PM
Teeks's Avatar
Yes.
Is it audibly loud on the timing chain side of the motor? I have had them fail before on my Honda's and I don't really recall it vibrating. Of course if you do the adjustment properly you can't hurt anything. Just make sure you don't over tighten or over loosen it, I would hate to have you cause damage.
I do not mean that offensively in any way, or is that a knock on you or your mechanical ability. I am just trying to simply state if you do not know what you are doing this is one adjustment you should not be making.
Teeks is offline
post #5 of 10 Old 10-18-2014, 11:33 PM Thread Starter
rosemont83's Avatar
It's cool man I appreciate the advice and warnings!
I rode his bike and something is definitely wrong. It could be the tensioner as well as something else in addition but I feel the cct should be first.
It's loud and it vibrates when the throttle is opened especially past 4k rpm but smoothes out at the higher rpms. Its most pronounced between 4.5k and 6k and is felt throughout the bike.
post #6 of 10 Old 10-18-2014, 11:45 PM
Teeks's Avatar
Yea that's the right rpm range to hear it for sure. Give it a go and see what happens. Good place to start, and ya cant hurt anything by making sure its in proper adjustment.
Teeks is offline
post #7 of 10 Old 10-20-2014, 02:08 PM Thread Starter
rosemont83's Avatar
So upon further inspection it looks like his isn't manual and its still the same stock automatic one.
I'm going to help him replace it. I know he should get a manual one but I don't think he'll be able to adjust it at the proper intervals so I think we should just stick with the same stock automatic one yea?
_________________
My Bike history:
1997 CBR1100XX Super Blackbird
2007 CBR1000RR
2013 ZX10R ABS
post #8 of 10 Old 10-20-2014, 04:23 PM
Teeks's Avatar
I put a manual one on my 954rr at like 38k miles. I sold it at 85k miles and cannot recall ever adjusting it, maybe once. Get the APE its superior imho.
Teeks is offline
post #9 of 10 Old 10-20-2014, 05:18 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
I'm with Teeks here, the APE manual tensioner is superior and way less hassle if it ever needs adjusting again.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #10 of 10 Old 11-19-2014, 12:14 AM
BigJay's Avatar
Thanks for the kind words guys. As for adjustments, there are a number of youtube videos up there now. You can do a search.
Speed Merchant
http://www.zxzone.com
BigJay is offline
zx10r 19k miles . cam chain tensioner help kawasakizx10rr The ZX-10R 2 08-07-2014 08:47 AM
Help with cam chain tensioner? knucklehead The ZX-10R 11 10-19-2009 05:13 PM
Cam Chain Tensioner Felix el gato Performance and Tech 4 09-17-2008 07:46 AM
New cam chain tensioner.. nczx-10r Performance and Tech 4 07-07-2008 11:53 PM
Cam Chain Tensioner 06/07 ZX-10's ?? WRECKSHOP The ZX-10R 7 07-18-2007 05:23 PM
