Gen 5: 2016- Cam Chain and Cam Chain Tensioner - Kawasaki ZX-10R.net
 3Likes
post #1 of 16 Old 02-24-2019, 11:12 PM Thread Starter
NocturnalMale74's Avatar
Hello all.... I'm new to the forum. Bare with me please... Ok get down to the facts. 2016 ZX10 just cleared 28000 miles. Been through the CCT under warranty and actuall recall... Recently had it adjusted because of slack... Chain is still making noise. I have gotten another option... Cam chain stretched beyond tensioner limits ?
Help... I'm still paying for this bike and thinking it might GRENADE on me..
Thanks in advance !
NocturnalMale74 is offline
post #2 of 16 Old 02-25-2019, 05:14 AM
97grnrs's Avatar
How loud is the noise and under what conditions
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #3 of 16 Old 02-25-2019, 03:54 PM Thread Starter
Loud on cold start but quiets down a little when it comes up to temperature but the guy that tunes my bike says there is no way it should be that loud after oil circulates and engine comes up to temperature. Like I mentioned 2 CCT replacements and one supposed CCT adjustment and still rattling. Is this the way a well broken in 2016 should sound ? I trust my Tuner Guy over the dealership unfortunately but my Tuner is more of a Suzuki guy and never seen or heard a gen 5 with 28000 miles. Just seems like a pretty expensive job after 3 years... I do a lot of of long distance... Out of state trips. If rather not have bike break down far away. Thanks for responding so quickly.
post #4 of 16 Old 02-25-2019, 03:55 PM Thread Starter
Ohh.... I'm listening to it at idle and also noticing it on down shifts coming to stop
post #5 of 16 Old 02-25-2019, 04:26 PM
ddipaola's Avatar
Just get the APE manual tensioner and adjust with your hand slowly till the noise goes away. Don't go torquing that b**** down or anything, just finger, FINGER, tight. Do a cold start adjust till the noise is faint or gone. Go out around the block. Come back with the bike warm, and if you still hear noise adjust 1/4 to 1/2 turn at a time, go around the block again, and repeat. It's better to be finger tight with faint noise then torqued the F down and no noise what-so-ever.
When in doubt... send it!
ddipaola is offline
post #6 of 16 Old 02-25-2019, 06:23 PM
97grnrs's Avatar
Some noise is normal. You don't want a super tight cam chain. I'd have to hear it to see, I've never trusted manual tensioner on an every day bike
97grnrs is offline
post #7 of 16 Old 02-25-2019, 09:39 PM
michael4012's Avatar
Any chance you can make a recording of the noise preferably inside and outside
michael4012 is offline
post #8 of 16 Old 02-25-2019, 10:57 PM Thread Starter
I'll see if I can get some video and audio tomorrow.
michael4012 likes this.
post #9 of 16 Old 03-29-2019, 02:41 PM
Cagill's Avatar
Hey I have a 2017 zx10r and it has only 7,000 miles and it makes a horrible cam chain noise! It's normal man I did a bunch of research and found out that's just how it is! You have to understand you are sitting right on top of the engine basically! If you rode around in your car while sitting under the hood you would think your car is gonna blow up ! Lol. Now that other guy is correct, use the ape cam chain tensioner and do exactly what he said and you will find that it can become alot less noisy . Now you could have an issue with yours but I highly doubt it! Mine is really noisy when it's cold and almost goes away when it's hot but then sometimes I'll hear it again so it is what it is, go buy the ape tensioner and you'll be happy. Oh one more thing, EJR PERFORMANCE on you tube, he is a badass bike mechanic especially with gen5"s and he even said the same things !
gaz likes this.
Cagill is offline
post #10 of 16 Old 03-29-2019, 03:44 PM
Formerly CLCRACINGAaron
Neonmarine's Avatar
About 2500 miles of track only use...2016 Gen5. That chain shouldn't be retaining it's original shape btw... KWS Motorsport told me that they replace the tensioner guide with the Gen4 part number and have never had to an issue.
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
Cam Chain Tensioner NinjaDan Performance and Tech 102 10-14-2016 05:02 PM
Upgraded Cam chain tensioner 04 ZX10 otto Performance and Tech 1 03-21-2007 08:42 PM
Manual cam chain tensioner or stock? bugman53 Performance and Tech 2 02-01-2007 03:26 PM
Cam Chain Tensioner 06zx10 TX06'10r Performance and Tech 11 11-05-2006 02:10 PM
Stock cam chain tensioner question! Superbike1 Performance and Tech 9 06-28-2005 03:58 PM
