calling the nitrous boys - Kawasaki ZX-10R.net
post #1 of 5 Old 11-16-2008, 11:01 PM Thread Starter
zx-sik-r's Avatar
slung a rod in my 1078 motor on the dyno this weekend so im a build a nitrous motor.goan run the 9:1 pistons.my ? is can i get a wet kit for this bike?
zx-sik-r is offline
post #2 of 5 Old 11-17-2008, 05:10 PM Thread Starter
zx-sik-r's Avatar
bump?lol so nobody knows nitrous around here?
zx-sik-r is offline
post #3 of 5 Old 11-17-2008, 05:39 PM
inappropriate
hesaves0211's Avatar
Images: 67
search button might help you out
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #4 of 5 Old 11-17-2008, 06:20 PM
Speed Freak
garth285's Avatar
yeah, it will be a custom application though, that or you can run a direct port DRY shot and get a hub for your PC3 run a relay so when nitrous is activated the hub will switch maps for you automatically and add the fuel to richen her up.... with 9:1 pistons I'm assuming your going to be running a massive shot of nitrous??? what size shot are you thinking of running? tuned right you can run a 60-80 shot dry with standard compression.... 9:1 is kinda low so your motor will make horrible power on motor.... if anything just get the bike set up right... if you get an ignition module you can have the second map pull timing for a large shot and still run normal compression.....
garth285 is offline
post #5 of 5 Old 11-17-2008, 08:32 PM Thread Starter
zx-sik-r's Avatar
i was thinkin like a 100-150 shot,i have an ignition module already,my head is already built with stainless valves,and ported n polished.i was just thinking of goin with pistons thinkin it will last me a bit longer and a lil safer maybe?
zx-sik-r is offline
Birthday Boys madnessracing The Out House 11 10-20-2007 05:23 PM
birfday boys!! Big Daddy The Out House 13 09-11-2007 05:03 PM
**NWS** These are R E A L boys... GRKZX10R Adult Content - Photos / Videos - N.W.S. 36 04-03-2007 08:28 PM
birfday boys Big Daddy The Out House 15 11-02-2006 08:47 PM
my boys are at it again rocketracermike The Out House 8 09-11-2005 11:44 PM
