Calling all DIY PCIII Installers...I need help !!! - Kawasaki ZX-10R.net
post #1 of 11 Old 08-01-2008, 05:43 PM Thread Starter
Drain Fade's Avatar
So I'm trying to get the damn throttle bodies off and I have to disconnect the PCIII from that big Brown connector. I totally forgot how to get the damn plug out...I've tried everything short of ripping it off. Anyone remember or recently install a PCIII that can tell me the secret to removing the big Brown plug ? What a PITA...I have an '06 BTW.
~Drain Fade
'06 Ebony Black, Supersonic Sport Tourer
A ton of shit....I want the farkles of a Gold Wing on a 150HP bike just over 400lbs ;)
Have a VFR, ZX9R or ZX10R, check out http://drainfade.com
Drain Fade is offline
post #2 of 11 Old 08-01-2008, 05:51 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
I believe the tab u need to depress is on the bottom of the brown plug.
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #3 of 11 Old 08-01-2008, 06:18 PM Thread Starter
Drain Fade's Avatar
Ur right...but still can't get it off.
~Drain Fade
post #4 of 11 Old 08-01-2008, 09:29 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
yes the tab on the brown plug is underneath..
look closely and you can see something like a slot on the tab..
just insert a screwdriver in it and pull up, and at the same time pull the plug out.
Lucky10R is offline
post #5 of 11 Old 08-01-2008, 10:27 PM Thread Starter
Drain Fade's Avatar
Now I'm starting to feel inept...'cause I can't get either of those fuckers off.
Here are pics of both...the brown plug on the fuel rail and the other plugged into the other end of the PCIII harness. Tell me what the hell I'm doing wrong. You can see my screwdriver pulling down on the other plug and that bugger doesn't budge. I'm scared of pulling one of the little wires out.
~Drain Fade
post #6 of 11 Old 08-01-2008, 10:45 PM
Lucky10R's Avatar
Images: 19
Insert the tip of the screwdriver on that slot that I put a circle on.
Pull it UP with the screwdriver while pulling the plug out.
Lucky10R is offline
post #7 of 11 Old 08-01-2008, 10:59 PM Thread Starter
Drain Fade's Avatar
Well alright...I finally got both damn plugs out. They were tighter than a virgins pussy on prom night. Thanks a ton....I wrote down the way to get them off now so I should be good to go. After this I'll probably just remember...what a PITA.
~Drain Fade
post #8 of 11 Old 08-02-2008, 01:27 PM
Images: 70
Kool glad u got them out the only reason i knew that was it is cause its a PITA like u said.
www.sportbikepc.com
post #9 of 11 Old 08-02-2008, 01:41 PM
ZX-10R_Sinner's Avatar
!! I was just rerouting some wires after installing my speedohealer last night, and I wanted to tuck the PCIII wires in nice and tight, I bet I spent 5 minutes before I got them off, and pulling the two apart up top sucked, man were they tight. I ended up getting the tab undone just a little, then prying them apart from the middle with a tiny straight blade. Glad ya got her worked apart, I wish I coulda helped at the time.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #10 of 11 Old 08-02-2008, 02:14 PM
inappropriate
hesaves0211's Avatar
Images: 67
grab a pointy object like a screw and push in on that tab as yourself or a friend kungfu grips the plug and pulls. fairly easy after the first time.
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
calling anyone is Socal bradshow01 The Out House 5 08-01-2008 05:35 PM
The ad that's calling you out! Hattori Hanzo Pictures and Videos 10 07-11-2007 08:54 PM
are there any car audio installers online n7myr The Out House 15 02-08-2007 09:47 PM
door installers EAST-LOS The Out House 0 12-17-2006 03:08 PM
Calling everyone in SE USA crispin Race and Stunt 66 06-13-2005 12:43 PM
