caliper swapping advice/info - Kawasaki ZX-10R.net
post #1 of 14 Old 12-18-2009, 08:30 AM Thread Starter
zedxten's Avatar
when i was running zx14 calipers on my 05 zx10r the brakes were insane.
i also had an rcs m/c
I now own a gsxr 1000 06, i kept my brembo m/c but the brakes are not quiet as AMAZING. " standard gsxr calipers " ( look the same as standard 04-05 zx10r calipers too )
will the zx14 zx6r calipers fit my bike?
are the o8/09 zx10r calipers a better choice, were they improved as the years went on? ( would they fit )
thanks , sorry for all the questions
zedxten is offline
post #2 of 14 Old 12-18-2009, 08:45 AM
Speed Freak
garth285's Avatar
well they have the same spacing bolt holes to bolt hole I know that.... I just dont know how spacing is I'm sure if you got some measurements someone could tell ya if they will work...
garth285 is offline
post #3 of 14 Old 12-18-2009, 10:26 AM
nickalltogether's Avatar
Don't get 08 brakes, the 14/6r calipers are worlds better (I have both on two different bikes).
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #4 of 14 Old 12-18-2009, 05:45 PM Thread Starter
zedxten's Avatar
ok, interesting - thanks
zedxten is offline
post #5 of 14 Old 12-18-2009, 05:57 PM Thread Starter
zedxten's Avatar
the calipers are the same on a 07 zx6r and a zx14 right?
but the disc size on a zx6r is 300mm
and disc size on a zx14 is 310 mm
is this right?
mine on the gixxer are 310 mm too.
i might be able to borrow some calipers and do a dry fit before commiting to a purchase anyway i guess
zedxten is offline
post #6 of 14 Old 12-18-2009, 06:18 PM
ZX-10R_04's Avatar
when installing GSXR calipers on the 10R they need 5mm spacers
so maybe the calipers need 5mm machined off them
Bmc filter, Hels Braided Brake lines, Nissin ZX14 Calipers, Brembo, RCS19 M/C, Ohlins damper,Fender Eliminator, Puig screen, Smoke Integrated taillight, Green front indicator lens's, Mirror block plates, Gauge Mod, Vortex rear sets, Personalized # Plate, Pazzo levers, 1/5th Throttle insert, H.I.D Headlights 5000k, Seat cowl, Gen 3 Swingarm, Titanium exhaust hanger , Racefit Growler ,GIpro TRE , Michelin pilot pures, -1 front sprocket, PCIII, SpeedoHealer v4, Factory Pro V Stacks
ZX-10R_04 is offline
post #7 of 14 Old 12-18-2009, 06:48 PM
Gone
is this right?
yes cals are the same but the forks aren't - the 14 has longer 'legs' on the bottom to make up the diff...
tony83 is offline
post #8 of 14 Old 12-18-2009, 06:58 PM
DEATH_INC.'s Avatar
The K3/4 ones don't, and they have 310mm disks. I had some on my 10....no spacers.
DEATH_INC. is offline
post #9 of 14 Old 12-18-2009, 07:37 PM Thread Starter
zedxten's Avatar
might do a dry fit with you original zx10r calipers mal and see how they go
zedxten is offline
post #10 of 14 Old 12-18-2009, 07:45 PM
ZX-10R_04's Avatar
Yeah sure thing Wayne seems the Tokico calipers & Nissin calipers are the same fit
That way you might get to see how the nissins might bolt up
Brembo Underslung Caliper Bracket and Caliper 9R to 10R Pictures and Videos 29 01-18-2009 12:14 PM
swapping wheels motomike Performance and Tech 11 05-15-2008 08:32 PM
More caliper info YO trackaddict Performance and Tech 44 08-06-2007 07:04 PM
Track School advice/info needed! Hoser Track 17 02-28-2007 09:17 PM
Possibly Moving to Texas (advice/info) iroman The Out House 23 01-09-2007 05:35 PM
