Busted valve and tappet - Kawasaki ZX-10R.net
post #1 of 2 Old 08-07-2008, 09:52 AM Thread Starter
cueman's Avatar
Busted valve
I justed replaced my motor with a used motor that is stock except a muzzy turbo i installed.I started bike it ran rough so i had to rev it to keep it running so i could adjust the idle after a few minutes it died and would not turn over.
I took the valve cover off and found a busted tappet on the #1 piston exhaust valve.
So thats no problem i got a extra complete head but after pulling head i find the valve broke in half and stuck in the piston,also found a bolt in there to.
I recieved the motor with out throttle bodes and has not missing any bolts when installing motor.
The cylinder wall is fine and i have 4 good stock pistons would it be ok to just replace that one are do i need to do moreClick image for larger version
cueman is offline
post #2 of 2 Old 08-08-2008, 12:48 PM
sextaafondo's Avatar
That bolt is what ruined your engine.
If I were you IŽd change the connecting rod as well. It probably got stressed when the piston locked.
sextaafondo is offline
Busted valve and tappet cueman General Motorcycle Discussions 10 08-10-2008 11:01 PM
busted tappet cueman Performance and Tech 8 08-05-2008 07:33 AM
frame busted kuziken10r The ZX-10R 41 04-27-2007 01:26 PM
Need help...Busted by the Po Po.... blackmagic The Out House 19 11-27-2006 03:20 AM
Busted My Oil Pan mikebar4 Race and Stunt 8 05-26-2006 05:59 PM
