Gen 1: 2004-2005 Building engine - Kawasaki ZX-10R.net
post #1 of 32 Old 09-28-2014, 08:47 PM Thread Starter
OxyG3nE's Avatar
Building engine
Sooo last year the generator kinda explode and it did not damage so far except for all the metal inside the engine.. i took it all appart and souldnt have much left..
now it is a spare engine and i want to boost it a little!
Before doing it any test i should do to the engine?
I Did my research and this si what i saw i should do
Akrapovic full line
secondary butterfly fully removed
Velocity stack kit
08 race intake cam
kawi .50 thin head gasket and head decked 10
Carpenter spring
and APE retainer
Thats the first time ill take appart an engine to "boost" it so i dont know much about it ..
What is the thickness of the gasket i need to get and how much material i should have remove from the head to keep it safe since ill be racing it?
What is the name of the tool i need to compress the spring to be able to get the retainer ?
OxyG3nE is offline
post #2 of 32 Old 09-28-2014, 08:51 PM
badassjake's Avatar
boost? as in turbo or supercharger?? or give it a boost in performance?
badassjake is offline
post #3 of 32 Old 09-28-2014, 08:54 PM Thread Starter
OxyG3nE's Avatar
a little boost in performance :p no turbo lol
OxyG3nE is offline
post #4 of 32 Old 09-28-2014, 09:54 PM
gazx10's Avatar
.45 mm hg should measure out and be better, .015-.20 deck, cnc valve job is critical for high rpm power. valve spring compressor for installing retainers. all safe and streetable assembled/degreed/tuned properly will make good power and torque.
gazx10 is offline
post #5 of 32 Old 09-29-2014, 06:02 PM Thread Starter
OxyG3nE's Avatar
When i look on the cometic web site , i dont see the thickness of the gasket ..
Do you know a web site where i can get it?
And what is the Cnc valve job ??
OxyG3nE is offline
post #6 of 32 Old 09-29-2014, 07:32 PM
tyler.nd@hotmail.com's Avatar
Building engine
Schnitz. cnc valve job is wen they recut the angle of valve n match with new or recut seats and somtimes square of top of valve to make sure square and there are other thing done as well but basically gives u much better tolerances etc for better power n less lost
post #7 of 32 Old 09-29-2014, 07:35 PM Thread Starter
OxyG3nE's Avatar
There are only 2 option in the head gasket size.. 0.027 and .018??
OxyG3nE is offline
post #8 of 32 Old 09-29-2014, 08:07 PM
gazx10's Avatar
.45mm = .018 gasket.
gazx10 is offline
post #9 of 32 Old 09-29-2014, 08:08 PM
Ya .18" is .45 and 27 " is 55 or 50 can't remeber
post #10 of 32 Old 09-29-2014, 08:23 PM
gazx10's Avatar
.027 = .65mm which is stock. each .05mm reduction =.002 thinner hg.
gazx10 is offline
Any Ohio people with engine building experience? Blue08 Suspension and Tire Tech 2 06-27-2014 01:46 AM
Building graffiti.. Bullshark Pictures and Videos 20 05-30-2010 11:48 AM
Building a Superbike ? kneedragger General Motorcycle Discussions 41 08-31-2008 09:38 AM
Building a ZX6R1 SOUN1 General Motorcycle Discussions 1 06-10-2008 02:49 PM
Building an 05 ZX-10 fstR1 Performance and Tech 9 08-04-2007 12:31 PM
