Buckets, shims and a block head - Kawasaki ZX-10R.net
post #1 of 19 Old 04-04-2006, 10:56 PM Thread Starter
Post Whore
1killer1liter's Avatar
Images: 11
When I picked up my head the first time to take it to the machine shop, I was a block head and turned the head over and the buckets and shims fell out. I know, I'm a bone head. I have never been inside of a motorcycle engine and thats why I took it my friends shop in the first place. Can someone point me in the right, but quick direction to get this head put back together smoothly?
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #2 of 19 Old 04-05-2006, 07:09 AM
The shims just sit in a little recess on top of the valve spring retainer, and the bucket slips right over the top of that. There should be a number on the shim (which indicates it's thickness). The number should be facing up when installing the shim.
Unless you get really lucky and happen to have all the same thickness shims in your head, you're going to have fun trying to figure out where each one goes. You'll just have to install each one, check tappet clearance, and go from there.
GeorgeC is offline
post #3 of 19 Old 04-05-2006, 10:33 AM Thread Starter
Post Whore
Images: 11
Damn. Thats what I figured. 16 buckets and shims. Thats going to take forever.
post #4 of 19 Old 04-05-2006, 10:44 AM
Unfortunately, no quick way at this point.
CanyonCarver is offline
post #5 of 19 Old 04-05-2006, 11:19 AM Thread Starter
Post Whore
Images: 11
Alright then. I'm glad I'm not the one putting it back together. I'll probably owe a little more than quoted, but I have to pay somewhere for my mistakes.
post #6 of 19 Old 04-05-2006, 05:42 PM
It does not take that long to do put all the higher #'s on the exhaust and the lower #'s on the intake from there its measuring and math
about 45 to 1 hour top's !!
http://aceperformance.com/
41 Land Speed record's 650 750 1000 1350 1650 2000 3000 3001+cc classes 236.96 MPH
Winner & fastest N.A. bikes of Texas Mile shootout N.A. and Nitrous class with NO NOS on bike.
223.33 MPH all motor Busa.
203 + MPH 2016 ZX10R
THE ICE MAN is offline
post #7 of 19 Old 04-05-2006, 06:20 PM Thread Starter
Post Whore
Images: 11
just called him and let him know. Thanks ice man.
post #8 of 19 Old 04-05-2006, 07:01 PM
MIA Ex-Mod
Tread70's Avatar
Higher the number the thicker the shim meaning less clearance put the smaller numbers on the exhaust and the bigger on the intake. The intake is supposed to be a little tighter than the exhaust. After install the cams torque down the caps check and write down your measurements and start calculating for correct clearance, uninstall swap and reinstall cams, check again and you may have to remove a third time to get them just right.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #9 of 19 Old 04-05-2006, 07:16 PM
Don't use full torque each time! there going to be in and out several times. And it's going to take longer than a couple hrs. Make sure who does it takes there time >now< no time to be in a hurry!
Dreadnought-arr is offline
post #10 of 19 Old 04-05-2006, 07:20 PM
MIA Ex-Mod
Tread70's Avatar
Yeah all you really need to do is just past snug tightness.
Tread
Tread70 is offline
2005 zx 10-r cylinder head and crank heavyd Parts, Gear and Accessories 0 02-15-2006 06:54 AM
