broken right rear set, neep input - Kawasaki ZX-10R.net
post #1 of 8 Old 01-09-2010, 09:53 AM Thread Starter
gmc52789's Avatar
:o 04 zx10 so i was takeing my rear sets off to send out to have powder coated and when i grabbed the brake lineadjuster on the rear of the rear set the metal tab on the back that holds the adjuster in please broke right off, anyone have this happen or have a fix for it? thanks!
its the adjuster that is attached to the rear brake light switch spring, its a small metal tab that holds the brake adjuster
ZX10- The Whip :deathmeta:
R6-Sold
CBR600-Sold
gmc52789 is offline
post #2 of 8 Old 01-09-2010, 10:17 AM
Send a message via Yahoo to crazyhawk99
Originally Posted by gmc52789 View Post
so i was takeing my rear sets off to send out to have powder coated and when i grabbed the brake line the metal tab on the rear of the rear set just broke right off, anyone have this happen or have a fix for it? thanks!
its the adjusted that is attached to the rear brake light switch spring, its a small metal tab that holds the brake adjuster
Which rear-sets (brand) on which bike? Also, pictures would help a reader understand your problem and recommend a solution.
"There are days when it takes all you've got just to keep up with losers."
Current Fleet:
09 BMW R1200GS
04 ZX10R
02 HD Heritage Springer
03 SV650
88 HD Sportster
crazyhawk99 is offline
post #3 of 8 Old 01-09-2010, 10:18 AM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
Done that...
order a brake light pressure switch and you wont need the oem adjuster anymore... or get a new bracket.
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #4 of 8 Old 01-09-2010, 10:35 AM Thread Starter
gmc52789's Avatar
it is a oem rear set on a 04 zx10.
R6-Sold
CBR600-Sold
gmc52789 is offline
post #5 of 8 Old 01-09-2010, 10:37 AM Thread Starter
gmc52789's Avatar
Originally Posted by 06blackpearl View Post
Done that...
order a aftermarket one i take it?
R6-Sold
CBR600-Sold
gmc52789 is offline
post #6 of 8 Old 01-09-2010, 10:39 AM
Images: 70
yes its about $25 check with the sponsors...
http://www.pjsparts.com/catalog/prod...ab7f7789a3ef49
www.sportbikepc.com
post #7 of 8 Old 01-09-2010, 11:25 AM Thread Starter
gmc52789's Avatar
so does it work the same way just hook the spring it it? or do i have to mod something?
R6-Sold
CBR600-Sold
gmc52789 is offline
post #8 of 8 Old 01-09-2010, 12:47 PM
Images: 70
No spring it removes all of that stuff the brake light comes on by the pressure (when brakes applied) that sends the signal to the rear brake light via cable that plugs in under your seat (right were the OEM cable goes)..
you will have to bleed the line..
www.sportbikepc.com
Broken Tab fix for Rear Brake Light.04/05 bluedevil Performance and Tech 23 02-02-2010 05:32 PM
Powerbronze rear hugger... need input! elninja_10r The ZX-10R 12 04-28-2009 03:29 AM
Attack rear set question-rear brake light switch? steves87 The ZX-10R 35 10-09-2006 04:47 PM
Broken Tab fix for Rear Brake Light.04/05 bluedevil How To... 1 05-10-2006 10:04 PM
