Gen 2: 2006-2007 Broken release spring? - Kawasaki ZX-10R.net
post #1 of 3 Old 04-22-2011, 03:56 PM Thread Starter
TexasRider's Avatar
I just noticed my release spring for my clutch (part #92145A on the diagram) is broke..dont know when it broke either. First question, can I keep riding with it broke? And second..do i have to pull the clutch cover off the bike to pull the release rod out to change the spring?
http://www.ronayers.com/Fiche/TypeID...9/Group/Clutch
TexasRider is offline
post #2 of 3 Old 04-22-2011, 06:15 PM
gazx10's Avatar
take the clutch cable loose from the rod, turn and lift out. that springs purpose is to keep the rod in proper position and tension to lock in with the pressure plate puller that releases the clutch.pay attention to its position before removal and when reinstalled, u may have to lift up just a little for it lock in place correctly. i would replace soon as it can get out of place and chew up the pressure plate puller.
gazx10 is offline
post #3 of 3 Old 04-22-2011, 07:15 PM Thread Starter
TexasRider's Avatar
Ok...sounds easy enough. Thanks. At $1.70ish I think ill order a few just in case.
Broken valve spring retainers found while doing valve adjustments Vio Performance and Tech 138 06-25-2014 11:22 PM
Pcv Ignition Module Release 09zx10miami Performance and Tech 21 05-19-2011 01:57 AM
New release suzuki 1000 k9 DAXENOX General Motorcycle Discussions 53 07-06-2008 02:09 PM
08 Model Release? 99vorsi General Motorcycle Discussions 1 12-22-2007 08:25 PM
RELEASE DATE? zixxer Archives 19 01-03-2004 12:38 AM
