Broken fuel pump terminal - Kawasaki ZX-10R.net
post #1 of 10 Old 12-29-2008, 11:27 AM Thread Starter
edouble's Avatar
Question Broken fuel pump terminal
I broke the fuel pump terminal on my 06 10r. I tried to soder it back on but failed. I was thinking about using JB Weld I know this has to be connected or else the fuel pump will not activate. I think this wire is a ground but I am not sure. Could I use one of the fuel pump's mounting bolts to secure this wire to? I have searched through the tech manual and wasnít able to find out what this wire is.
edouble is offline
post #2 of 10 Old 12-29-2008, 11:41 AM
Postwhore with an 04
bcm0018's Avatar
It does just look like a ground wire so I don't see why you couldn't secure it to that bolt. If not I would drill a small hole in the plate and put a seperate nut and bolt on it. I would try something none permanent and see if it works.
bcm0018 is offline
post #3 of 10 Old 12-29-2008, 12:21 PM Thread Starter
edouble's Avatar
Drilling into the base of the fuel pump is sketchy. I am not going to do anything until I know for sure what this wire is and if it has to be attached to the post I broke off.
edouble is offline
post #4 of 10 Old 12-29-2008, 12:32 PM
bcm0018's Avatar
I definitely agree with you on that! Maybe get a regular fuel line that is a little longer so you can start the bike with the fuel tank proped up far enough to fiddle and see if it will start with it attached to the bolt.
bcm0018 is offline
post #5 of 10 Old 12-29-2008, 12:36 PM
Supercharged Mod
100% sure that is a ground wire - the connection is not insulated from the base plate. Just connect it to the other bolt as you have planned.
GoFaster is offline
post #6 of 10 Old 12-29-2008, 02:26 PM Thread Starter
edouble's Avatar
Thanks. Does anybody else know for sure if it is a ground wire or not? I am cautious cause I dont want to f$%^ something else up.
edouble is offline
post #7 of 10 Old 12-29-2008, 07:50 PM
Quick10's Avatar
There is no way that it's anything other than a ground...Power wires don't get connections like that
Quick10 is offline
post #8 of 10 Old 12-29-2008, 08:11 PM Thread Starter
edouble's Avatar
Alright tomorrow I will fasten the wire to one of the pump's mounting bolts and hit the start button.......and pray.......
edouble is offline
post #9 of 10 Old 12-30-2008, 11:44 AM Thread Starter
edouble's Avatar
I bolted the wire down to one of the fuel pumps mounting bolts. I started the bike and everything seems fine
edouble is offline
post #10 of 10 Old 12-30-2008, 09:35 PM
sextaafondo's Avatar
Thatīs the ground both for the pump motor and the fuel level switch.
sextaafondo is offline
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
WTB 04-05 fuel pump... Nukedog Wanted: Buy or Trade 1 05-05-2008 06:12 PM
help with 636 fuel pump reckless1 ZX-6R & ZX-6RR Archives 5 06-08-2006 10:57 PM
fuel pump not on reckless1 ZX-6R & ZX-6RR Archives 0 06-08-2006 05:42 PM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
