Bridgestone BT002RS tires - Kawasaki ZX-10R.net
post #1 of 37 Old 05-14-2007, 07:17 PM Thread Starter
Smile Bridgestone BT002RS tires
So I got my new tires mounted and went out for about 20 miles. They feel great so far but I think most new tires feel great after removing the stockers. Im ridding them on the street with 32 PSI front and rear. Has anyone else ran these tires? Im plannning on taking them to the track and I would like some feed back on tire pressure for both the street and track on these if anyone has any? The real test will come this weekend when I put 100 miles on them and I will give a review.
P.S. I still have 5mm ride height added to the rear and have not decided if I will take it out or leave it. Curious if anyone running these made height adjustments front or rear. Thanks!
jessiah1 is offline
post #2 of 37 Old 05-14-2007, 07:28 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
I have the rear not the front, So far im pleased with it.
air pressure was 35 at last check
i dont race. only street but i did not change the height as it is the stock size 190/55.
The bike seems more nimble, like ready to turn on a dime.
will be getting front soon.
my rear was $200 mounted and balanced
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #3 of 37 Old 05-14-2007, 08:18 PM
nelly250's Avatar
i just bought a set of these for my first upcoming trackday and maybe first race, i'll have them mounted by the end of the week. I went with the 180 rear so i'd like to hear about ride height suggestions as well as right now im running stock ride height with the 636 knuckle/dogbones
04zx10r - Yosh rs3 s/o ^ Ohlins Damper ^ Penske 8987 ^ Traxxion Forks ^ Woodcraft Rearsets ^ PC3usb ^ DJ Quickshifter ^ Radial 6rr Master ^ Galfer lines ^ 1/5 throttle ^ 636 linkage ^ Renthal 15-42 ^ 520 conversion ^ Double Screen ^ K&N Filter ^ Champ Sliders ^ Flexiglass Race Bodywork
nelly250 is offline
post #4 of 37 Old 05-14-2007, 08:27 PM Thread Starter
Well I know the 190 55 rear is narrower than the stock quali by a bit and it does help turn in a lot. Not sure how the 180 compares.
jessiah1 is offline
post #5 of 37 Old 05-14-2007, 08:30 PM
I really want to try these tires.... I recently added 8 mm to the rear height ... just to make the bike turn quicker and it REALLY helped a lot...
I have an 05 btw.
fordfasterr is offline
post #6 of 37 Old 05-14-2007, 09:30 PM
10roller's Avatar
theese are the tires i was askin about last 2 months ago, and nobody knew nything about theese tires. im eager to know also.
10roller is offline
post #7 of 37 Old 05-14-2007, 10:21 PM
nelly250's Avatar
yeah, i hadn't heard of them until last week, but i'll have them on the track may 26/27 so i can give my opinions then
nelly250 is offline
post #8 of 37 Old 05-15-2007, 07:52 AM
jtemple's Avatar
I bought my '05 used and it has a set of these on it. They aren't too bad, but worn. I have new tires that will go on when my new fork seals come in.
jtemple is offline
post #9 of 37 Old 05-15-2007, 08:01 AM
I bleed Green!
whispering smith's Avatar
Images: 21
Tried them last track day. Ok until the second round they turned to grease. Just my 2 cents. Good luck and keep it safe.
Riseing Sun 2000 ZX-6R
Green 2004 ZX-6R 636
Every day is a new beginning.
www.stealeyconstruction.net
whispering smith is offline
post #10 of 37 Old 05-15-2007, 02:49 PM
Yogotta B. Biking's Avatar
I have been using the BT002R (medium) compund road race tyre since last July. The tyre says either street or race on the sidewall.
In any event, they stick like dung to a sheep. My Ten was great with these tyres. They are quite expensive as a set, and made a deal with my mate. We would buy a set and I would carry 45% of the cost, and he uses them in 2 heats at a race meeting. I then use them on the Ten.
They are great and I have seen at track days Im one of a handful of riders using them. Most ppl either fit the Corsa or Michelin instead.
I stick to the BT002, period.
then for fun I drive a british racing green MINI Cooper S
Yogotta B. Biking is offline
Bridgestone BT-015 smason5 The Out House 0 10-10-2006 09:55 AM
New tire From Bridgestone... vizsladog The ZX-10R 12 07-02-2006 04:03 PM
Bridgestone tires zx10Roger Vendors deals 0 06-21-2006 07:16 PM
Bridgestone BT-014s Tires litrejunkie Performance and Tech 12 06-16-2005 10:33 PM
Kwak and Bridgestone king-tony Race and Stunt 0 04-11-2005 04:13 PM
