Brembo MC: Which Brake Light Switch? - Kawasaki ZX-10R.net
post #1 of 6 Old 12-29-2005, 05:14 PM Thread Starter
Tito's Avatar
Those who have a brembo master cylinder, which brake switch is best for street/track use?
1. Brembo mechnical switch ~$60
2. doube banjo 2 wire pressue switch ~$20
Issue: Apparently the 2 wire pressure switch is flakey, you need to significantly apply the brakes b/f the brake light turns on.
Question: With the pressure switch setup, does it need lots of pressure to the point where it is unsafe to run on the street?
Trying to figure out if its worth spending the extra bucks.
Thanks in advance
Tito
04 ZX10R
05 ZX6R
Tito is offline
post #2 of 6 Old 12-29-2005, 08:35 PM
I think its best to get a good switch. On my ZX-9, for a while I was always getting cars almost hitting me from behind to the point I was getting really pissed at cagers in traffic and stopping. Then In a garage one day I noticed my brake light was not working too well due to the switch malfunction, so they (cagers) could not tell I was braking and, not being able to judge my speed, almost kept whacking me in the arse. Once I put a new switch on, no problems...well mostly. Cars have a hard enough time as is with bikes......don't give them even more and less braking distances...
MDZX10 is offline
post #3 of 6 Old 12-30-2005, 12:28 AM
Supraman78's Avatar
Images: 11
use the back brake first...doesn't it set off the brake light too? especially since that thing is soo spongy anyway
Supraman78 is offline
post #4 of 6 Old 12-30-2005, 08:41 AM
Pressure switch works fine for me. IMO, mechanical switches are much more likely to cause problems.
CanyonCarver is offline
post #5 of 6 Old 12-30-2005, 12:09 PM
Big Daddy's Avatar
Images: 38
yup use the pressure switch.
Big Daddy is offline
post #6 of 6 Old 12-30-2005, 01:48 PM Thread Starter
Tito's Avatar
Thanks guys, pressure switch it is. If it really sucked than i'm sure i would hear about it. I may use the rear brake a little more in high traffic situations.
Happy New Year
Tito
04 ZX10R
05 ZX6R
Tito is offline
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Brembo MC 19x18 and SS brake lines Tito Vendors deals 32 12-29-2005 03:07 PM
rear hydraulic brake switch for the 10R-$15 shipped steves87 Parts, Gear and Accessories 6 05-20-2005 05:04 PM
rearsets using stock brake light switch on1whl Performance and Tech 4 03-06-2005 03:20 PM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
