Brembo MC? - Kawasaki ZX-10R.net
post #1 of 6 Old 06-07-2007, 09:08 AM Thread Starter
Ninja187's Avatar
Brembo MC?
Can someone explain the difference between the 16x16 to the 19x20 dimensions on the brembo mc's? What would be ideal for the 10?
GEN 4: Brembo HP calipers, Brembo HP T-Drive Rotors, Brembo RCS master cylinder, Fren Tubo SS lines, re-valved Ohlins damper, Ohlins TTX shock, Yoshimura case covers/frame sliders, Yoshimura 3/4 R77D Ti exhaust, BMC filter, Puig DB, Renthal Clip ons/sprockets, attack rearsets, Guhl flash, kawi kit throttle, Ballistic EVO2 8 cell, Annitori RL quick shifter, Dunlop rubber.
Ninja187 is offline
post #2 of 6 Old 06-07-2007, 09:17 AM
19x18 for 10R, just do a search, you'll find plenty of threads about it and also you will find info on 636 M/C.
Hattori Hanzo is offline
post #3 of 6 Old 06-07-2007, 10:15 AM
19 is the bore, 16, 18 and 20 are the lever ratios, I've tried 16 and 18 levers on my Brembo and can't say I've noticed much difference, the improvement just by fitting it is the noticeable gain. I've got a black 18 Pazzo shorty lever on it at the moment.
doug_uk is offline
post #4 of 6 Old 06-07-2007, 02:33 PM Thread Starter
Ninja187's Avatar
I see a 16 18 and 20 in the 19x__, so i'm assuming that the 16 is the shortest pull and 20 is the longest pull?
Ninja187 is offline
post #5 of 6 Old 06-07-2007, 02:42 PM Thread Starter
Ninja187's Avatar
http://www.oppracing.com/pages/artic...ter_cylinders/
Found a great write up on it and found the answers to all my questions here.
Ninja187 is offline
post #6 of 6 Old 06-07-2007, 05:43 PM
A good article, what I noticed on my Brembo was the brake hose bore size was different from the stock setup, I had to get a matching Brembo reservoir and hose.
doug_uk is offline
Brembo RMC, Fom 05 to 07? SUPER K Performance and Tech 5 05-24-2007 05:05 AM
brembo m/c #'s? coastiepete The Out House 5 02-05-2007 03:05 PM
Brembo grover Vendors deals 15 12-18-2006 12:54 PM
636 m/c vs. brembo m/c.... latdrop Performance and Tech 17 04-01-2006 08:42 AM
brembo rocketracermike Performance and Tech 10 02-27-2006 06:47 AM
