Gen 3: 2008-2010 brembo master cylinder question - Kawasaki ZX-10R.net
post #1 of 11 Old 01-11-2011, 09:32 PM Thread Starter
hi
i got 08 10r track bike. i'm looking to upgrade brake master cylinder with brembo. wich one will work better for full time track bike 19x20 or 19x18 ? what is the difference ?
thanks
mokry33nj is offline
post #2 of 11 Old 01-11-2011, 11:01 PM
flthy1's Avatar
Originally Posted by mokry33nj View Post
hi
thanks
19X18 will give you more feel, 19X20 will require less lever travel for more power. Get the rcs brembo, you get the option to choose between the two. Lots of write ups on this!
flthy1 is offline
post #3 of 11 Old 01-12-2011, 09:53 AM
bird_dog0347's Avatar
Images: 11
I have an 08 with the RCS master, Galfer superbike lines, and ferodo XRAC pads... this thing stops FAST! I rode with 19x20 on the track most of the year but switched to 19x18 the past two track days and the only difference I noticed was a little more rear end stability on initial bite. The rear end did not want to come up in the air as much, but my brake markers were still the same and still moving closer to apex. Just get the RCS and see what you like best. I am pretty sure TENN10 (member here I bought from before) has one for sale.
bird_dog0347 is offline
post #4 of 11 Old 01-13-2011, 11:43 AM Thread Starter
thanks guys. that's all i have to know.
post #5 of 11 Old 01-13-2011, 12:37 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
hey BD....you still run the stock rotors with that setup?
TMY10ER is offline
post #6 of 11 Old 01-19-2011, 08:18 PM
Do you run 2 lines off the master cylinder, one for each caliper, or 1 line and split with a "T", then run a line to each caliper?
-P
Goshawk is offline
post #7 of 11 Old 01-20-2011, 02:06 PM
Images: 11
Yep, I still run stock rotors... I have two sets of wheels and stock rotors on all of them.
post #8 of 11 Old 01-20-2011, 02:08 PM
Images: 11
-P
Some kits are 1 into 2, some are 1 from master to caliper, then 1 to the other caliper... Mine is 2 lines off the master to each caliper, Galfer superbike lines.
post #9 of 11 Old 01-20-2011, 02:10 PM
RDLYN13000's Avatar
Images: 38
I just picked up a 19x20, I hope it isn't to aggressive for the streets!! Lol
RDLYN13000 is offline
post #10 of 11 Old 01-20-2011, 02:52 PM
TMY10ER's Avatar
just don't squeeze it too hard!! i think you'll fall in love with it broski
TMY10ER is offline
Brembo master cylinder Feanor The ZX-10R 23 08-07-2010 04:09 AM
Which Brembo master cylinder do I get? PumpinIron The ZX-10R 21 05-31-2010 08:43 AM
question about brembo master cylinder bolt mack10r The ZX-10R 5 10-27-2009 10:15 PM
Brembo master cylinder lanmac30 Vendor Deals 1 04-22-2008 09:54 AM
